65 Honda 140 convertible
I have the motor out of my car and have re sealed the push for tubes, now I would like to replace the crank seals, how hard is this to do?
Re: 65 Honda 140 convertible
Honda? I don't know anything about them. The rear seal in a Corvair is easy. The front is more work. Bell housing and oil pan have to come off but it isn't difficult. You'll want to replace the input shaft seal on a manual or converter seal & bushing if a Powerglide while you are in there. Be sure to add fluid if a Powerglide before starting it. You can ruin the converter bushing if it doesn't have fluid.
