Brake master cylinder
ss64II
Post by ss64II »
Hi
Whats the best brake master cylinder for a front disc brake conversion? I'm looking at the Dorman M89160 for the '69 Camaro but would be interested to see what else others are using.
Its for this 65 Monza below-
Re: Brake master cylinder
Have always used the later Corvair dual master cylinder with good results.
triumphcorvair
Post by triumphcorvair »
Which disk brake conversion are you using? Scarebird? I'm also guessing that the DM cylinder from Clark's is for front/rear drum brakes only?
Darrell McCracken
Huntsville, TX
Darrell McCracken
Huntsville, Texas
triumphcorvair wrote: Fri Aug 24, 2018 7:34 am Which disk brake conversion are you using? Scarebird? I'm also guessing that the DM cylinder from Clark's is for front/rear drum brakes only?
Darrell McCracken
Huntsville, TX
I have used Clark's front disc conversions in conjunction wioth the 67-69 dual master cylinders with no issues. If you are intending to put some monster calipers on the front brakes then perhaps a master cylinder with a larger reservoir for the fronts might be needed. For the( 80's cutlass??) calipers used in the Clarks conversion the standard later dual master is fine.
ss64II
Post by ss64II »
Hi
Im using Vauxhall Senator discs, hubs and calipers, 270mm discs, off the rear of the Vauxhall - I'm in the UK and the bearings for the Vauxhall hubs fit right on the GM spindle.
