Horn screws
Caudillo63
Horn screws
Post by Caudillo63 »
Happy 4th of July to everyone. Getting ready to take steerring horn ring off and there are some screw head I never seen. Any idea? I don't want to strip it.
Steering
Steering
toms73novass
Re: Horn sxrews
Post by toms73novass »
They are called clutch head. They quite often come is a multi set of bits. Here is a link to an ace ad for some, not sure if they are the correct size.
http://www.acehardware.com/product/inde ... WQQAvD_BwE
1962 700 Wagon
1963 Spyder convertable
1965 Monza
1967 UltraVan 211
Re: Horn sxrews
A small flat blade screw driver can often be used if they are not to rusty. Do not strip them so you can get a proper clutch head if need be,
Caudillo63
Re: Horn screws
Thank you very much
Re: Horn screws
Clutchhead screws were common on the FC's since GM's truck division was fond of them for some reason. Sometimes you find them in the cars.
Rumor has it GM originally used them to avoid paying a royalty on Phillips head screws - hard to say.
If you are not into factory correct you can replace them with the more common Phillips head used in the cars.
Re: Horn screws
I seem to remember finding these screws in the Powerglide transmission also.
Wikipedia wrote:Clutch
Screw Head - Clutch Type
Image Type A
Image Type G
Type A clutch head screw
Clutch Head Driver Sizes
Driver size
​ 1⁄8″
​ 5⁄32″
​ 3⁄16″
​ 1⁄4″
​ 5⁄16″
There are two types of clutch screw drives: Type A and Type G. Type A, also known as a "standard clutch", resembles a bow tie, with a small circular "knot" at the center. These were common in GM automobiles, trucks and buses of the 1940s and 1950s. Type G resembles a butterfly, and lacks the center "knot". This type of screw head is commonly used in the manufacture of mobile homes and recreational vehicles. The clutch head was designed to be driven with a flat-blade screwdriver as well as a clutch driver.
:link: https://en.wikipedia.org/wiki/List_of_s ... ves#Clutch
guru_1071
Re: Horn screws
Post by guru_1071 »
mine came undone easily with a small flat bladed screw driver
