Telescoping Steering Wheel
gregpenn
Post by gregpenn »
I need to access my turn signal accuator. How do I remove the telescope tension/lock ring on the steering wheel to be able to pull the wheel? Also, is the button on the tension ring supposed to serve as a horn button? I have a horn but can't figure out where anything is to press. Thanks.
65 Monza conv.
Sent from my SM-N910P using Corvair Forum mobile app
thewolfe
Re: Telescoping Steering Wheel
Post by thewolfe »
The horn button has 3 clips on the back that clip it into place. You have to carefully pry the horn button out then you will see how to remove the rest.
Nate Wolfe
65 corsa 180
gregpenn
Post by gregpenn »
Thanks. It's so tight I was afraid to try to put a screwdriver in there. I'll try to find a thin plastic pry tool.
I don't believe the spring-steel clips would hold it that tight. Perhaps a clip broke at one time and a previous owner used some type of glue to secure it. Although this theory doesn't solve your problem, it is a possibility you might come across.
Here is an illustration of the telescoping steering wheel assembly for the 1965 Corvair. The section of the 1965 Corvair Assembly Manual that is applicable is attached.
Telescoping Steering Wheel (1965)
:chevy:
1965 Corvair Assembly Manual - TELESCOPING STEERING COLUMN.pdf
(758.07 KiB) Downloaded 27 times
gregpenn
Post by gregpenn »
Thanks. Got the disk off no prob, and this diagram shows #9 as horn button. I'm guessing that plate should rock to accuate the horns. I'll dissasemble it, now that I have access to it. Thanks for the helpful advice.
dave t
Post by dave t »
The parts place has reproductions of most of the tele horn parts available. Thepartsplaceinc.com
gregpenn
Post by gregpenn »
Thepartsplace didn't have much for Corvairs.
nmunn
Post by nmunn »
Does anyone know where repro parts for a tele column can be found. I looked on the ThePartsPlace and didnt see anything.
thewolfe
Post by thewolfe »
Here's a link for 65-66 tele column parts. The same parts are used in the corvette columns. They also have 67 tele column parts
http://www.corvetteamerica.com/cf/displ ... oryid=X925
Nate Wolfe
65 corsa 180
cnicol
Post by cnicol »
I've purchased tele wheel parts from Long Island Corvette. They have a good selection. http://www.licorvette.com/
nmunn
Post by nmunn »
Thank you both. Does this mean there is a corvette column that is interchangable?
nmunn
Post by nmunn »
I found a column, thank you.
dave t
Post by dave t »
The parts place has most of the parts you are working with in case you need replacements
erco
Post by erco »
I have a '67. Is the telescoping column not the same as the "energy absorbing" column, which became standard in '67? I need a new turn signal switch, Clarks shows 2 different types for 67's, C863 and C864 (which is what I have).
"Is the telescoping column not the same as the "energy absorbing" column?"
Telescopic is for adjustability energy absorbing is for crashing.
erco
Post by erco »
Excellent, thanks for that. How does it adjust?
Is it possible I've had this car for 40 years and never knew it adjusted?
