Help with my tag
- 66corsaguy
Help with my tag
Hello can you guys help me to figure out my tag and
And also is this engine original to this body?
Re: Help with my tag
Welcome to the Corvair Forum!
BODY TAG INFO:
01C
Body Build Date: 01 = January, C = Third Week
The first two digits are numbers 01 through 12, indicating the month of manufacture. The letter is A-E, indicating the week of the month. If the letter is an "C" it indicates the third week of the month.
66-10737 LOS 1041 BODY
Style: 66 = 1966 10737: 1 = Chevrolet, 07 = Corsa, 37 = 2-Door Sport Coupe,
LOS = Los Angeles (Van Nuys), California, Production Sequence No: 1041
1966 Chevrolet Corvair Corsa 2-Door Sport Coupe - 4 Passenger, Total Production: 7,330
TRim: 722-Z = BRIGHT BLUE (MONZA 10500 and CORSA 10700 SERIES — Bucket Front Seats)
This 3 digit codes represents the interior color and seat type.
On 1966-67 models the extra digit denotes whether the car has optional headrests or not. E = headrests on bench or bucket seat cars built in WRN in 1966 and bench in 1967. Y = headrests on bucket seat cars built in Los Angeles or buckets built in WRN in 1967. Z = Corvair trim designator on LA built cars only. 1966 Willow Run cars without headrests, have this area left blank.
Paint: F-F = BRIGHT BLUE "Marina Blue"
Lucite No. 4704L, Rinshed-Mason No. A1823, Ditzler No. DDL 13148
Example — 1966 Corvair Corsa Coupe in Marina Blue with Bright Blue Interior
ACC = Accessory line
E 2S 5Y
GROUP 1
E = RPO A01 — TINTED GLASS (Soft Ray glass in all windows)
GROUP 2
S = RPO U73 — Antenna, Radio Rear, Manual
GROUP 3
NONE
GROUP 4
NONE
GROUP 5
Y = RPO A39 — Deluxe Seat Belts (Stainless Steel Push-button Buckles)
T0319RB
0319 = Engine manufacturing date (month and date). March 19th.
RB = 1965-1966 164 CID 140 HP Manual Transmission (Corvair Corsa Only)
This guide will show you how to decode the VIN tag...
107376Lnnnnnn
I have attached a copy of the 1966 Chevrolet Corvair GM Heritage Center Specs for your model year Corvair.
BODY TAG INFO:
01C
E 2S 5Y
GROUP 1
GROUP 2
GROUP 3
NONE
GROUP 4
NONE
GROUP 5
T0319RB
107376Lnnnnnn
Sorry to say the engine is not original to the car. Car body made in 3rd week of January, engine made March 19th. The engine date has to precede the body date; usually by one to three weeks.
- 66corsaguy
THANK YOU so much. I was starting to figure out some of it but started getting a little confused. Looks like the tag matches what I have and the restoration was kept as close to original as possible I will post my car soon and introduce myself as I am getting ready to jump into some changes and will have a good amount of questions
- 66corsaguy
Thanks for that. A mechanic I worked with when I first purchased had said he thought motor was not original to car so he is rightcnicol wrote:Sorry to say the engine is not original to the car. Car body made in 3rd week of January, engine made March 19th. The engine date has to precede the body date; usually by one to three weeks.
