TRUCK VAN CLUTCH CABLE
joe moore
Post by joe moore »
WHAT IS THE LENGTH OF THE PULL. LET ME START OVER WHEN YOU DEPRESS THE CLUTCH PEDAL HOW MUCH CABLE IS DRAWN BACK TO ENERGIZED THE THROUGH OUT BEARING. I. DON'T THINK I HAVE ENOUGH. THANKS JOE
Sent from my IdeaTabS2109A-F using Corvair Forum mobile app
1962 rampside #3957
gerg
Re: TRUCK VAN CLUTCH CABLE
Post by gerg »
Wow - this is an old thread but I also have a '62 FC and I am fighting cable adjustment.
Adjusting by the book I cannot get the trans in gear when running.
I adjust by the book and then I need to take that 3.5 turns back in - shortening the clutch rod just to make it drivable.
Feels like all the slack is gone between the clutch bearing face and the cover spring fingers.
Late model stepped flywheel with correct cover and bearing. New Clark's cable. Hmmm . . . :doh:
Thanks,
gerg
1967 Monza, 110, PG & AC
1962 Rampside 110, Factory 4-speed & 3.89 Posi
Monroe, LA
fred bagnall
Post by fred bagnall »
I purchased a Clark's repo clutch cable a few months ago. I seemed to have some stretching the first few days, which required me to readjust a couple of times before I had it working the way I wanted it to. I was a little worried at first because I had to adjust quite a bit more than the factory original one. :tu:
Did you use the correct pivot ball?
