Front brake line 64 spyder
I am replacing fuel tank on 64 spyder and am going to replace the driver side brake line which way to snake out the old line and in the new. Getting out the old line not a problem new one in only want to do once (if that). Thanks
Re: Front brake line 64 spyder
Poke it thru the grommet hole in the inner wheelhouse and rotate it like a crank handle. Properly formed line will pretty much rotate into place (can be done without too much trouble with the tank in the car even).
If you are removing the tank, I would replace the right side brake line also. To get the right side into its retaining clips, the tank needs to be out.
Chris Brown
Member
CORSA
Member
CORSA
True this. You can change the right line without completely removing the tank (fully loose, sway bar out all but removed) but it is a pain in the butt to do so by all means if the tank is out change it also.funvairs wrote:If you are removing the tank, I would replace the right side brake line also. To get the right side into its retaining clips, the tank needs to be out.
