VOTE - Corvair of the Month January 2016
Voting Now Open
- Gregory_Miller
Re: ENTER - Corvair of the Month January 2016
Back for more, my 65 CORSA clone. I've had all the engine tins powder coated and blocked off the fresh air hose with DaveMotohead's kit for a cleaner looking engine compartment.
Getting close to cutting over to Ray Sedman's DIS then eventually to his EFI as well. I've also replaced most of the rubber trim and next on the docket is Clark's molded carpet kit, which may now have to wait after the missus spent 3 days in the hospital to end the year.
Degreeing the cam:
Yes, it's really an ISKY 280.
Added some hidden speakers and cleaned up the look of the rear package area behind the back seat. Seats have fabric centers for comfort in the hot summer months.
Degreeing the cam:
My 1966 Monza, it was my Dad's and then his mom's before we got it in 1986.
110 and 4 speed, front disc brakes, Clark's 140 HP exhaust
- corvair-russ-expedition 039.jpg (85.94 KiB) Viewed 2219 times
Maybelline is our 1st Corvair purchased in 2005. 110hp on PG with A/C , power top and remote mirror. We should have done this decades ago!
- Gregory_Miller
I like Maybelline's color a lot.
I'll give this another shot. My 65 corsa turbo. Stocko wackos might hate my car but I have put a lot of time and effort into making it what it is. Here are a few shots and my current mod list(that is after I get my suspension stuff powder coated and back into the car).
Engine:
.020 keith black hyper-eutectic pistons
turbo distributor with vacuum advance
pertronix ignitor and coil
safeguard timing control, knock sensor, electronic boost retard
Tom Knoblauch performance 95 hp heads:
quench area welded up to gasket surface for more squish
larger stainless valves(140 exhaust, cut down 140 intake)
deep valve seats
bronze valve guides
140hp exhaust tubes
intake and exhaust ported
chambers cc'd 8:1 compression
chambers, valve faces, exhaust ports, and back of exhaust valves ceramic coated
HD springs and titanium retainers
heavy duty push rods
heavy duty rocker studs
modified Comp Cams SBF chrome moly roller tip rockers
140hp exhaust manifolds
custom exhaust crossover 1.63” mandrel bends with waste gate flange, wrapped
all exhaust piping, turbo exhaust housing ceramic coated
Magnaflow muffler
Rajay b flow exhaust turbine, e flow compressor, Rajay compressor housing
Sedman progressive secondary modified Weber 40dcoe carb, custom turbo manifold
38mm Tial waste gate
Holley electric fuel pump, regulator, pressure gauge
stock fuel pump bypass plate
econo aluminum oil pan
Otto deep oil pickup
Otto aluminum valve covers
6 puck spring loaded carbon/metallic clutch disc
1500# HD pressure plate with weights machined off
hydraulic clutch conversion, Wilwood master and slave cylinders
Dale bolted flywheel
Dale harmonic balancer
Dale spring loaded idler pulley
HD rear engine mount
Greddy profec b electronic boost control
Cooling Mist water/methanol injection
Devil's Own injection nozzle, holder
AEM wideband o2
Autometer boost gauge
Sunpro oil pressure gauge
Optima battery
Suspension and steering:
Clark's HD springs cut one coil all around(2” drop)
front lower control arms modified to accept Chrysler screw in upper ball joints(1” drop)
QA1 adjustable lower ball joints(K772 style)
spherical bearing(Johnny Joint) lower control arm bushings
spherical rod end(Johnny Joint) brake reaction rods, custom mounts
chrome moly tubular upper control arms, Chevelle ball joints(K5108)
graphite impregnated poly upper control arm bushings
Leveque modified stock steering arms for quick steer and less ackerman
adjustable bump steer kit, heim ends, aluminum adjuster sleeves
Sadek crown style 1” tubular front sway bar, poly bushings, heim end links
Sadek 3/4” tubular rear sway bar, poly bushings, heim links
nylon pitman arm bushing
reinforced drag link
front disc brake conversion – Stoptech cross drilled S10 rotors, Wilwood calipers
braided stainless front and rear brake hoses
Porterfield R-4S rear drum shoes
Wilwood BP-10 front pads
dual master cylinder(70's C10 manual front disc/rear drum)
Koni adjustable front and rear shocks
spherical bearing(johnny joint) rear torque arm bushings
upper strut rods removed
PMT fabrication adjustable lower strut rods(urethane bushing one end, Johnny Joint rod end on other end)
redrilled crown lower strut rod bracket
rebuilt telescoping column, C3 Corvette wheel
Foose legend 17x7 wheels, 205/40/17 front, 225/45/17 rear
Other mods:
Corbeau LG1 reclining bucket seats, double locking sliders
Mulholland Drive front air dam
clear euro front turn signals
custom headlights:
clear H4 conversion housings, Morimoto mini H1 bi-xenon projectors
Morimoto 5000k HID bulbs
Xentec ballasts
LED halo retrofit, adjustable PWM dimmers
rear tail lights have LED rings in conjunction with the incandescent bulbs
shaved antenna
JVC cd player
Pioneer 6x9s in rear, stereo front speaker replacement, slim powered sub behind driver's seat
chrome fire extinguisher between front seats
heavy duty clutch cross shaft bracket
suspension, engine tins powder coated along with many other parts
ceramic tinted windows
eastwood hot rod black paint
Engine:
deep valve seats
bronze valve guides
140hp exhaust tubes
Magnaflow muffler
AEM wideband o2
Optima battery
Other mods:
custom headlights:
Xentec ballasts
shaved antenna
JVC cd player
Nate Wolfe
65 Corsa 180
61 Lakewood 140
65 Corsa 180
61 Lakewood 140
"Stocko wackos"?!? Ouch!
"Stocko wackos" as opposed to "Mod Monkeys" hehe
CORSA Member #034095
No offense intended! Stocko wacko is the term I've seen used here and other forums for the guys that prefer to keep their cars as original as possible. There is certainly nothing wrong with that and I appreciate good, original cars. I also see customs that make me want to puke. My personal preference for any car that I own is to tweak it to my liking to suit my taste and driving style. Different strokes for different folks
Nate Wolfe
65 Corsa 180
61 Lakewood 140
65 Corsa 180
61 Lakewood 140
Seeing light for the first time in around 30 years.
1960 Corvair 700 Deluxe 4Dr
This is my entry for this month. A 1966 Corsa conv. 140 HP 4spd. with factory a/c. Car was finished in Feb. last year and has won several awards at local car shows.
1958 Chevy Impala
1966 Corsa Conv.
1966 Corsa Conv.
- croderique
Hi, How do you 'vote"? This is where to "Enter" but I don't see anywhere to "vote". Is there a different link to vote or where are the radio buttons to vote?
Thanks
Thanks
Chuck Roderique
1966 Corvair Monza Convertible, 110 H.P. 4 sp, Aztec Bronze with Bronze Interior
The voting will begin as soon as ten vehicles are entered or on the 1st of the month.croderique wrote:Hi, How do you 'vote"? This is where to "Enter" but I don't see anywhere to "vote". Is there a different link to vote or where are the radio buttons to vote?
Thanks
We're slow starting off this year but when voting is open you'll see that radio button selection list appear at the top of this thread.
