![helpsos :helpsos:](./images/smilies/helpsos.gif)
Sorry in advance
![rofl :rolling:](./images/smilies/rolling.gif)
I know this question has been asked about a billion times, but I've never found an exact answer. Let's say I'm going to run STOCK suspension, with HD coils and the 2 inch drop S10 spindles in the front(do these change the backspacing at all? also the ones modified by levair). I was told this changes the BS needed by 3/8"??? What would be the perfect backspacing for a 15x7 rim?? I know people say 4-5", but what is the best? Do I just cut it down the middle and go 4.5? I hear 4 rubs, and then I hear is doesn't rub, then the same with 5, then I hear about one guy running 3.5" BS and he has no issues. I don't know what to think or believe, but I want to get a set of new minilites made for my car, and I want them to fit!!!!!
![angry :angry:](./images/smilies/angryfire.gif)
I want to be able to hit bump stops while flying into a corner (not saying I'm going to do this) and have no tire rub, wheels locked in either direction. I plan on running a 205/60/15 in the front (or the corresponding 14" size), and a 225/50/15 in the rear(same as before). I also am worried about the 15" tire availability. Would 14s be easier to find tires for? I have seen a few threads about that, however they're all like 4-5 years old. Also, on the autoxer site, it says you can fit a 235/14, but only a 225/15?? All of this confuses me, I don't think the wheel well knows what size the rim is!
What I'm asking basically is the PERFECT backspacing, with a disc brake conversion in the front!(if I convert rear, will the BS change using corvair underground's kit?) I hope I don't make too many people mad with this post, haha! Thank you for any help I get, and hopefully this post will help some other people in the same boat as me as well.
