Head torque specs and sequence
Danthesignman
Post by Danthesignman »
I`m torqueing heads on a 140 tomorrow and have no manual and no idea . Help please , trying to get to the convention .
Re: Head torque specs and sequence
Torque spec is 32-38 ft lbs. Pattern is as follows: XXX are upper nuts or rocker studs looking at the head from teh valve cover side
-12--------8--------1---------4--------6--------10
XXX-----XXX-----XXX-----XXX-----XXX-----XXX
-11-------7---------3---------2--------5--------9
hope that helps.
Danthesignman
Very Cool ! , If I bust ass I can get the thing running by tomorrow .
Thank You !
Mcwho
Post by Mcwho »
Terrible,
Are your head studs torqued ok, didvu use heli coils, time serts, or original block threads. Any pull out?
Sent from my SM-G965U using Corvair Forum mobile app
Note this thread is originally from 2010.
Most Vair experts these days (2020) recommend torquing at 30 ft# max to prevent pulling the studs out of the engine case no matter if they have original threads or use repair inserts. Some rebuilders will use a piece of sturdy pipe to test each stud individually at 35 ft# before they actually install the heads and torque to 30 ft# so that if one threaded hole is weak they will find it earlier while the case is still apart and easier to repair.
65 Corsa 140/4
66 Corsa 140/4
66 Corsa 140/4 w/factory A/C
66 Corsa 455 Toro V8
65 Monza Convertible 110/4
66 Monza Convertible 140/4
I also always torque to 30 foot pounds. Above I gave the shop manual spec and copied and pasted that diagram from somewhere.
Per Azdave the general consensus is to use 30 ft lbs. for the head torque, then recheck after some time to "settle". The manuals had several different ratings, all seem to be too high. The caveat here is the stud threads must be clean and smooth.
I've never had a head gasket leak using 30 ft lbs.
Danthesignman wrote: » Fri Jun 18, 2010 10:36 pm
I`m torquing heads on a 140 tomorrow and have no manual and no idea...
A 13/16" Deep Socket and 9/16" Socket is needed.
HEADNUTS – ORIGINAL STYLE:
Used ONLY on Upper Head Studs These have the original style built-in “collar”, (just a flat washer under a regular nut is not suggested). Our head nuts are heat treated & have been tested to over 55 ft/lb., however, they should not be reused after the engine is run & the nuts removed. Head nuts and rocker studs should only be torqued 32-34 ft/lb. For all Corvairs. 12 needed to do two (2) heads.
CHROME ACORN NUTS: Install after the headnuts to keep the ends of the studs from rusting (for upper studs).
:link: https://ssl.corvair.com/user-cgi/catalo ... ow_page=13
Part number C1089: NUTS-HEAD-SET 12 PLATED (SET 6=C4633) CHROME ACORN NUTS TO COVER END OF STUD =C3413
Weight: 0 lbs 6 oz
Catalog Page(s): 13(69),20,181,329,OT-4 40(RM19)
Price:
1 - 1 $ 6.20
Part number C3413: NUTS-12 CHROME ACORN-UPPER HEAD STUDS
Weight: 0 lbs 6 oz
Price: $ 15.20
:wrench: :chevy:
1965 Corvair Chassis Shop Manual - SECTION 6 - ENGINE.pdf
(19.37 MiB) Downloaded 13 times
