Page 5 of 5
Re: Project: 1964 Corvair Monza 900 coupe in Hot Springs, A
Posted: Sat Oct 06, 2012 6:53 pm
by 65corvaircopnj
I changed to silicone when installing a whole new system a few yrs ago. A little more $$ but keeps the moisture away and minorwheel cylinder leaks don't kill the paint. My 2cents
Posted: Sun Feb 24, 2013 5:31 pm
by RedLightBrew
Finally got the Brakes bled and working again. Still a little work to be done on the brakes as far as replacing the rubber lines, but it is again drivable. I also still need to cut out the driver's side floor and replace with the beautiful new panel that I have. That's next.
Posted: Tue Feb 26, 2013 11:19 am
by RedLightBrew
Pulling hard right when braking. The left rotor is in need of turning or replacing. Might be too far gone. Switched rotor sides and pulls hard left, so I'm sure it's the rotor. Anyone have experience with the turned rotors from Clark's? Do they come with bearings already in or will I need to make the switch when it gets here? My local shops that turn rotors say it's too far gone for them to turn. I can order a used turned rotor from Clarks and send them the old one to see if they can do anything with it. The other front rotor is in really good shape and doesn't need any work. Must have been replaced at some point.
Posted: Mon May 27, 2013 4:55 pm
by RedLightBrew
Brakes are squared away... Drives nice now. Trans leaks a bit when I park it after driving and stops after a few tablespoons drip. Leak on top of transmission somewhere??
Next, cut out driver's side floor and weld in new pan.
Posted: Mon May 27, 2013 4:59 pm
by Scott H
RedLightBrew wrote:Brakes are squared away... Drives nice now. Trans leaks a bit when I park it after driving and stops after a few tablespoons drip. Leak on top of transmission somewhere??
Good to hear that you're continuing your progress and that its driving nice now. :tu: That sucks about the leak. Probably something pretty easy to fix :fingerscrossed:
Posted: Wed Jun 19, 2013 6:47 pm
by RedLightBrew
Posted: Thu Jun 20, 2013 10:15 am
by Gregory_Miller
I like the wheels.
Posted: Thu Jun 20, 2013 4:17 pm
by Scott H
It looks great!!! :tu: :chevy:
Re: Project: 1964 Corvair Monza 900 coupe in Hot Springs, AR
Posted: Fri May 24, 2019 6:16 am
by Migilla
5 years with no update?
How did it make out as a DD?
Posted: Sun Jun 16, 2019 2:55 am
by HotManInMS
Just finished reading this. Great pic of the parking. Rake setup. I needed a photo as whoever's had our car previous Jerry rigged up something that diesnt work.
