I have not had much trouble with Corvair wiring, except a few cases where someone patched it poorly, and this car had almost no rust. If it had salt corrosion, I would expect corroded wiring, but other than the rear harness (which appears to have been damaged due to somebody doing some really dumb things that caused them to get hot/burn), all the wiring I've looked at has been fine. Even the fuse panel is in better condition that other, newer vairs I've owned. I have never had any wires on a vehicle chewed by animals, not even in a couple of cases where mice or a rat lived in the car for awhile, so I doubt any of the wires on this car have been chewed. I think it's likely that the remaining causes are simply due to light corrosion at connection points from the car sitting for so long.bbodie52 wrote: ↑Mon Nov 12, 2018 6:24 amAlthough I cannot be there to examine your actual wiring, your description makes it sound like there must be a voltage drop somewhere between your reconnect point and the voltage source. But when you bypass the rest of the harness by connecting directly to the battery terminal your new wiring is functional. If it stops working when you connect the wire back to the multi-connector, then the voltage drop must exist internally within the multi-connector or at some point on the other side of the wiring harness as it is routed to the voltage source. A bad wire or a bad connection anywhere in the path between your reconnection point and the battery could be causing a reduction in voltage or an open condition that is preventing the complete circuit from functioning. The trick is to find the location of the high resistance or open condition that is causing the circuit to fail. Testing your wiring by connecting it directly to the battery terminal only proves the quality of your new wiring. But reconnecting that same new wiring back to the original source on the wiring harness, and then having it fail to function, only proves that you have more problems further down the pipe. The wiring you replaced may have indeed been faulty, but then reconnecting the new wiring to the old wiring harness only verifies the poor condition of the wiring harness throughout the car. Sounds like you're facing a complex and time-consuming task to restore the wiring throughout your car to an original working condition. A complete fix may be costly, either in time or money, or both. I am not sure what has caused such extensive deterioration in your Corvair wiring harness. Most aging Corvairs do not suffer from such an extensive breakdown in electrical wiring.VairsRule wrote: » Sun Nov 11, 2018 10:26 pm
...It's odd that the new backup light wiring does not work in place, but works fine when connected directly to the battery, and that half of it worked in place before...
I took another look at the wiring diagram you posted. Am trying to trace the path of the wires and points where I can do tests along the line, specifically, the power source to the backup light switch (where does this original from?) and the wire between backup light switch and engine harness plug. It shows a 14 guage light green wire
This diagram shows a BACK UP LAMP SWITCH, but in parentheses, it says "(Auto Trans.)". I wonder why? It's it a single pole switch in either case? Of course, the schematic does not show the PHYSICAL LOCATION of anything, so finding things on the car can be a challenge.
The schematic shows what appear to be two MORE harness plugs, each with 6 sets of terminals, to the left of the BACKUP LAMP SWITCH. There are "loops" around the wires leading to/from these plugs that indicate they are together. One "loop" says "WIRING HARNESS ASM. INST PANEL", and the other says "WIRING HARNESS ASM. MAIN". I assume the first is on the back of the instrument cluster (which I have not been able to remove yet). On the schematic, they are side-by-side. Are they BOTH in the back of the instrument cluster? I have not seen anything that looks like them.
