Weatherstripping
Posted: Fri May 09, 2025 10:36 am
Next little thing I wanted to try was getting some of the door weatherstripping replaced. 85% of it is a dried out, crumbling mess. The only 2 little pieces I have done so far were the rear 1/4 window to door window seals. Not too bad of a job, getting the old stuff out without bending anything too bad or hurting glass was the scariest part.
Until I started on it, I never knew that the qtr window trim strip with the weatherstrip literally just pulls off the glass. No tools needed for me, just a little scary, lol.
Here is the removed strip, just pulled from the glass with the new strip from Clarks beside it.
New strips are pretty nice, with the only caveat being they do not have the metal strip in them like the originals do. Didn't seem to make much difference. Hardest part of everything was getting the old weatherstripping out of the channel without bending the chrome too much. I found it easiest to take some pliers and going down the old strip a couple inches at a time to break the seal from the rubber to chrome. I did this on both sides and then was able to pull/twist/break my way until I got the old strip out.
My chrome isn't too bad on the outside, but the inside and some of the channel was crusty.
I scrubbed it all up with 0000 steel wool, and paid extra attention to cleaning out the channel. While there wasn't any sealant I know of on the originals, I put one little pea sized dollop of 3M Weatherstrip Adhesive a couple inches from both the top and bottom since there isn't the metal support strip in the replacement. Just insurance against slipping.
The glass side also has a bonded rubber in the channel to protect the glass. Mine looked pretty good, so I just did a good cleaning of it and again put a small pea sized dollop in the channel for insurance.
Back installed and looks much better.
Haven't started on the door seals, fuzzies, or roof line seals yet, so we'll see how that all goes soon.
