w e seem to have gotten past the 100 degree days............it was just too hot to do anything..............I think we have come up with the first fix as to the running slightly hot. We are going to add a scoop to the bottom. Our little spoiler we had below the radiator turned out to be about 2 inches too short to accomplish anything.
Our solution is a simple scoop hanging a little lower than the bottom of the car. These pictures show the first fitting of the scoop
what you see in this picture is the opening below the car for the air intake. You can also see fuel lines, brake lines and emergency brake cables along with some of the electrical runs. The scoop hangs way too low in this picture but you can start to get the idea of what it will look like.
.this is from the back side of the scoop. We will probably cut about 4 inches off the scoop and add braces to stop any movement at speed
We should have some idea if this solves any problem by the weekend
