disc brake conversion
Re: disc brake conversion
ReedBecky,
Im selling the brackets from California Corvairs to convert LM Corvairs to disc brakes. It comes with instructions to convert them. California Corvairs sells them for $129. I would take less. IM me if you are interested
Tim
Tim
65 Arrival Blue Monza
64 Palomar Red Monza
How about EM disc brake conversions? What has been used out there? Is the best way to go with a kit from Clark's?
1962 Monza 900
Levair Performance & Restoration in Anderson IN. can supply front and rear disk brakes for both early and late Corvairs.
LeVair Performance & Restoration
http://levairperformance.webs.com
4627 North State Road 9
Anderson, IN 46012
(765)617-9307
email: mlevair@sbcglobal.net
Anderson, IN 46012
(765)617-9307
I went ahead and pulled the trigger on the EM brackets from California Corvairs. I found a pair of 71-79 Dodge Colt Rotor/hubs. Now looking for Calipers. Does anyone know if aftermarket is acceptable for the conversion? The instructions make it a pint to have (used) in brackets for the hub and rotor but not for the Calipers. thanks for the read.
1962 Monza 900
Thank you all on your suggestions. I will be looking at them and the parking brake issues on the rear disc.
Thanks again
Thanks again
I have a Lakewood that had been converted to use the 77 Dodge Colt disc brakes. Clark's has them as a kit.
HI, I have drum brakes all around on my 1966 Monza. They are spongy and the pedal bleeds off at stops. The auto shop said this is normal and can't be corrected. Is this right? I am thinking of disc's to fix this.
Facebook https://www.facebook.com/pg/LeVair-Perf ... e_internal
The link below does not work. It indicates that the website is "Frozen".
http://levairperformance.webs.com/
The brake shop doesn’t know what they are talking about. Do you think Chevy could have sold this as normal?dirtdancer wrote:HI, I have drum brakes all around on my 1966 Monza. They are spongy and the pedal bleeds off at stops. The auto shop said this is normal and can't be corrected. Is this right? I am thinking of disc's to fix this.
If the pedal goes to the floor at a stop, it is normally the master cylinder. Spongy is usually air in the system. Run, don’t walk, from that brake shop and find someone who knows what they are doing.
Frank Metasavage
66 Corsa 140 4 speed Stock
- jbjr37@gmail.com
David Clemens, your For Sale post has expired. Can you re-post if you still provide the Disc Brake conversion? Pictures? Anything? I am interested in Front and Rear.
John Bennett
jbjr37@gmail.com
John Bennett
jbjr37@gmail.com
