Just disconnect the vacuum advance and plug hose and see what happens. Vacuum advance mainly improves fuel mileage under light engine loads and of course at idle there should be no ported vacuum to the advance can.joelsplace wrote: ↑Thu Mar 07, 2024 7:56 am I'm not having any issues where a main jet would help. This is at idle and just off idle.
New info: Mechanical timing does not advance too quickly. It actually advances much slower than it should. No mechanical advance where the knock occurs. It does have vacuum advance on just opening the throttle as you would expect. I'm thinking it needs a restriction in the vacuum line to slow down the advance along with a check valve that lets the vacuum dump quickly so it can back off at normal speed. Anyone tried that?
I tried a tank of 89 octane and the problem returns but not as bad.
Price premium is .80 on 93 and .40 on 89.
If the problem goes away, then yes a restriction will help slow it down as the throttle is opened off idle. Or maybe it is just a vacuum can with a weak spring.
