If the brake shoe linings are not cracked, or discolored in places, they should be fine. Brake shoe linings are either bonded on by adheasive or they are riveted on. I avoid riveted brake shoe linings because they can damage the brake drum when the lining wears down. If your drums are smooth, no deep grooves or rust pitting, they should not be an issue. I'd inspect all the parts to make sure they are in the proper place. The adjuster wheels at the bottom are DIFFERENT for each side. A lever (usually worn out and available) will push down on the projections from the adjuster wheel to tighten the brakes. You can push down on the lever to move the wheel and it should TIGHTEN the brakes shoes (move them further apart). If the brake shoes are adjusted too loose or too tight (one side vs. the other) than can cause pull to one side. There should be a slot in the brake drum to insert a tool to manually adjust the brake wheel. Sometimes the brake drum has no slot, just a oblong mark the supposedly can by "knocked out". I've never had one I could "knock out" and I drill the hole and slot it. Clark's sells a rubber plug to insert in the adjuster hole.auquomes wrote: ↑Tue Oct 18, 2022 6:23 am That's really intesresting to read all that.
That's understood regarding the lead substitute, I won't do anymore I promise!
Regarding my brakes, I changed my rubber brake hoses like 2 years ago when I bought the car so I don't think the issue comes from this side.
My brake shoes don't look so dirty neither (no oil) but they are probably very old so I'm pretty confident changing them may solve the brake issue.
Oh! Originally the brake shoes had shorter linings on one shoe vs. the other (often replacement brake shoes use the same lining length on ALL shoes). See attachment for orientation.
