Page 2 of 3
Re: Duncan's 1963 Monza build
Posted: Wed Sep 01, 2021 2:31 pm
by bbodie52
Posted: Tue Sep 07, 2021 3:27 pm
by mr.duncan
Posted: Mon Nov 29, 2021 4:26 pm
by mr.duncan
I know, I know a lack of updates.
Just a little teaser of some things to come soon...
Still waiting on the crossmember to come back from the powdercoater.
![Image](https://i.imgur.com/iLBAON7.jpg)
Posted: Mon Jan 03, 2022 4:18 pm
by mr.duncan
Posted: Mon Jan 03, 2022 5:21 pm
by bbodie52
Posted: Tue Jan 04, 2022 8:30 am
by mr.duncan
bbodie52 wrote: ↑Mon Jan 03, 2022 5:21 pm
I wish you were here! I have a 1966 Monza with a front end that would benefit from such craftsmanship!!
Bring it over.
Posted: Wed Jan 05, 2022 7:27 am
by mr.duncan
Whew! That was quick.
A good friend of mine helped me assemble and install the crossmember to the chassis.
Factory primer (redish-orange paint) looks great! - I assume that's factory paint.
All new grade 8 hardware used.
Upper control arm bolts, and lower control arm bolts are not torqued to spec yet, as im waiting to load up the suspension.
New front suspension springs from clarks.
![Image](https://i.imgur.com/NrO9jp2.jpg)
Posted: Wed Jan 05, 2022 8:36 am
by flat6_musik
Stupendous! I don't know how I missed this thread!! WTG! You're going to develop a "perma-grin" on your first test drive, I suspect.....
![clap :clap:](./images/smilies/clap.gif)
Posted: Thu Jan 06, 2022 5:35 am
by sparrow
Looks great! I am doing my front suspension also, just a few steps behind you!
Posted: Thu Jan 06, 2022 7:52 am
by Beers
Excellent work Thomas, that front suspension looks outstanding!
Posted: Sun Jan 16, 2022 1:32 pm
by mr.duncan
Welp.
Placed a large order at Clarks today for a new brake system. Everything is getting replaced. EVERYTHING.
Once I finish the front brakes, I'll spin the car around remove the engine and rear suspension...
100% rebuilding the entire suspension and brake system.
Front brakes:
![Image](https://i.imgur.com/YRgw42m.jpg)
Posted: Sun Jan 16, 2022 7:59 pm
by flat6_musik
That's the kind of stuff that causes the endlessly grabby/pulling brake applications.
Posted: Mon Jan 17, 2022 7:50 am
by mr.duncan
flat6_musik wrote: ↑Sun Jan 16, 2022 7:59 pm
That probably explains the HARD PULL to the right I had when applying the brakes.
Posted: Fri Mar 04, 2022 6:27 pm
by mr.duncan
Well,
I didn't pay attention to the brake shoe spring locations, or type of springs for the brake shoe retainers.
I've got: a regular non-tapered spring, and a spring with a coil taper/point to the end.
As for the retainers: Shallow retainer, and deep sitting retainer.
Does this look correct?
![Image](https://i.imgur.com/Q5006Of.jpg)
Posted: Sun Mar 20, 2022 5:40 pm
by mr.duncan
Installed the driver side front hub/brake drum today. Including new bearings / wheel seals.
Empty hub:
New bearing race installed:
Packed both bearings with fresh grease:
New wheel seal:
![Image](https://i.imgur.com/uB7ciZS.jpg)
Posted: Sun Apr 03, 2022 11:10 am
by mr.duncan
Finished replacing the passenger side brakes today.
Before:
Leaking wheel cylinder:
New wheel cylinder, and brake shoes:
![Image](https://i.imgur.com/4fF43Wa.jpg)
