Mike Fissel wrote:msfissel » Fri Sep 28, 2018 10:29 am
It was the glove box light, but this has been a very valuable experience and great info for debugging the electrical system!
Electrical troubleshooting and fault isolation seems to many people to be a great mystery. On newer cars — with their more-complex high tech electronic circuitry — it is more difficult to master. But on the Corvair the relatively simple, basic circuitry is much-easier to learn. If you understand how a circuit functions and how it was designed to operate, you basically understand what "normal" should look like. Learning how to use a multimeter is A KEY ELEMENT TO EFFECTIVE TROUBLESHOOTING OF AN ELECTRICAL CIRCUIT. Without it you are blinded to what is going on, and correcting an electrical fault would be much-more difficult. Experience and the right test equipment goes a long way. I hope this experience has helped you to build confidence in this aspect of maintaining your Corvair.
Here is another "tool" that can raise your level of knowledge, understanding and experience...
Automotive Wiring and Electrical Systems
Tony Candela, January 1, 2009
CarTech Inc
Often, wiring and electrical work intimidate automotive do-it-yourselfers more than anything else. It's not mechanical, and therefore, it's unfamiliar territory. Electrons are invisible, and to an untrained enthusiast they can do unpredictable things. Finally, here is an enthusiast's guide that takes the mysteries and misunderstandings out of automotive electrical design, modification, diagnostics, and repair.
Automotive Wiring and Electrical Systems is the perfect book to unshroud the mysteries of automotive electrics and electronic systems. The basics of electrical principles, including voltage, amperage, resistance, and Ohm's law, are revealed in clear and concise detail so the enthusiast understands what these mean in the construction and repair of automotive electrical circuits. All the tools and the proper equipment required for automotive electrical tasks are covered. In addition, this in-depth guide explains how to perform more complex tasks, such as adding new circuits, installing aftermarket electronics, repairing existing circuits, and troubleshooting. It also explains how to complete popular wiring projects, such as adding late-model electronic accessories and convenience items to earlier-model cars, installing relay systems, designing and assembling multi-function circuits and harnesses, and much more.
With this book in hand, you will be able to assemble, design, and build single- and multi-function circuits and harnesses, troubleshoot and repair existing circuits, and install aftermarket systems and electronics.
Automotive Wiring and Electrical Systems is the perfect book for wiring a hot rod from scratch, modifying muscle car electrical circuits for cooling fans and/or power windows, or adding a big stereo and other conveniences to modern performance cars.
https://www.amazon.com/Automotive-Wirin ... ny+Candela
In this revised edition, brilliant color photos and explanatory step-by-step captions detail the installation of the most popular, functional, and beneficial upgrades for enthusiasts of varying skill levels. This volume is essential for anyone looking to upgrade his or her classic vehicle to modern standards.
Here is another, older book that is a valuable part of the Petersen Publications (Hot Rod Magazine) series that taught me much in the 1960s and 1970s. It is still usually available as a used book for a couple of dollars. Its age places it right in a timeline that matches many classic cars like the Corvair, so the content is not really "obsolete".
Petersen's Basic Ignition and Electrical Systems, No. 5 5th Edition
by David N. Wenner (Author)
https://www.amazon.com/Petersens-Basic- ... c+ignition
