Looking for opinion on front spoiler
morevair
Post by morevair »
All,
Got a 1966 Corsa 4sp/140... It's currently got the stock air dam... When traveling at highway speeds 65+, the front is really lite... I am aware that the stock "spoiler" is intended to block air from approaching from below. My question is... the after market "Camero style" spoiler, does it offer more "down force" ? or is it just looks... plus I've seen different versions of this type of spoiler... wrapped, ported... etc. Is there any advantage to this design ? or is it just looks ?
Opinions welcome... thanks
Jeff M. in Phoenix, AZ
1966 Corsa 140 4-speed
steve57
Re: Looking for opinion on front spoiler
Post by steve57 »
Hmm, I have a stock air dam on my 69 and don’t notice in lightness in the front end. 70+ speeds on the freeway. I do have spare in trunk. Are your tire pressures adjusted correctly?
Steve
Bakersfield,CA
1969 monza coupe
110, 4speed
Tire pressures need to be considerably lower in the front than the rear in general on Corvairs spoiler or not. My late model cars I run around 32 rear and 22 front. I have had both stock and more slanted fiberglass units...I fell the fiberglass units I have used have just a slight edge at highway speeds but are certainly not as durable.
66corsaguy
Post by 66corsaguy »
terribleted wrote:Tire pressures need to be considerably lower in the front than the rear in general on Corvairs spoiler or not. My late model cars I run around 32 rear and 22 front. I have had both stock and more slanted fiberglass units...I fell the fiberglass units I have used have just a slight edge at highway speeds but are certainly not as durable.
I thought that tire pressure was just early model? Should i be putting my tires at 22 up front? I have 15” radials
Nope factory speced tire pressure differentials were for all years. In fact the tire decals on 65 models state 26 rear and 15 front for the original stiff sidewall biased ply tires. I have run 15" radials at 18-22 on the front before no issues, but fell that anything under around 20 cold is a bit squishy. If they are low profile and I might run more like 34-35 rear and 24-25 front, but, I always run roughly a 10 psi differential. Tinker with it a little and you find what works best and what the tires like wear wise as well. If you run them even all around the front end will tend to be lite and the front tires will also tend toward over inflation type center wear. Moving weight to the front like spare helps the nose lite tendency and if enough weight is in the nose then less pressure differential might be ideal. I have never found even to be ideal under any load.
It's been a very long time since I've driven a Corvair on the freeway with an original factory air dam so I can't do a fair comparison to that one but adding the early Camaro air dam made a noticeable difference to several of my 65's that had no air dam from the factory.
When it comes to the aftermarket choices, I can't tell a difference in driving between the flatter style and the wrap-around style units seen below but the S10 wrap around I used on the yellow Corsa had to be narrowed and was much harder to install than the air dam on the white Monza.
MonzaDave
Post by MonzaDave »
Mine is currently unobtanium, but is similar to the old Corsa Enterprises spoiler. The car is very stable up to at least 93 (which is where the Wyoming Highway Patrol interrupted my search for maximum velocity).
Dave Keillor
Rochester, MN
Years ago a debate on the other forum about the effectiveness of the 66 and later stock spoiler vs. none in 65 suggested the 66 and up spoiler was noticeable move effective than nothing.
Ted's right on the tire pressure if you are running the same size front and rear.
I run a bigger tire in the rear and moved the battery and tire up front. I only run the fronts a couple pounds less and have no issues. Not suggesting you do that, but just moving the spare up front helps if you don't mind losing some trunk space. BTW - all the A/C cars had the spare up front. The only reason GM moved the spare to the rear was because a Ford Falcon ad in 1960 dinged the Corvair for a "little trunk" so GM moved the spare to the engine compartment - not the best for weight distribution. Also that's why the 61 panel was revised, not for styling but to add a couple inches to the advertised trunk specification.
Yes the Corvair and Falcon had quite an advertising war going on in 1960 and 61. In 1960 the Falcon six was 144c.i. and the Corvair was 140c.i. In 1961 the Corvair engine increased to 145c.i. and that folks is why ONLY five c.i. was added so GM could make the claim the Corvair engine was bigger!!
Mark zaba
Post by Mark zaba »
66vairguy wrote:Years ago a debate on the other forum about the effectiveness of the 66 and later stock spoiler vs. none in 65 suggested the 66 and up spoiler was noticeable move effective than nothing.
Early Camaro front spoiler a must do for the EM Corvair
15179631324973a4e663d0dc660548b90cb493f523610c9fda2ac2c73616aaa41190265f74c0533bf71db92c0acafaaedfe8e3dc24ba0ffe239891de1fdce9612f315c65afeff.jpg
dave t
Post by dave t »
Classic industries has on for rather little $. I had one on my 63 spider before it was stolen. Only problem was the reduction of front end clearance. I could cruise at 70 with no problem. I also had rebuilt the suspension and steering so everything was tight.
morevair
Post by morevair »
Thanks all, for your input, I’ll probably stick with the stock spoiler for now, so many other things to do on my vair...
