Electrical system upgrade and restoration update.
DeadHorse
Post by DeadHorse »
Good day to everyone!
I posted here as I was starting my restoration and you all are awesome in sharing what you know. I have a 1966 Corvair Monza that I purchased last Christmas. It was in good shape but like cars of its age had rust in normal places and a not so pretty paint job. I have the body work done so now on to the power systems. What I am looking for advice on is the replacement or update of the electrical system and the fuse box. Are there turnkey solutions or a full replacement that you would suggest?
Pics of progress follow. Original color as purchased
After bodywork
Thanks in advance for any assistance/response.
acarlson
Re: Electrical system upgrade and restoration update.
Post by acarlson »
Not sure what wiring you're thinking of upgrading, but for a replacement fuse panel you might consider these:
viewtopic.php?f=80&t=13427
viewtopic.php?f=80&t=13481
Alec
Alec Carlson
Dahlonega, GA
Restoration "In Progress"...
:clap: :tu: Love the dark blue (Cobalt Blue?) color you've chosen for your Monza. The only thing I would have changed (personal preferance) would be to adopt the Corsa Silver found on original 1965-66 Corsas and on a number of Chevrolet products from that period. I think the contrasting silver would look great in contrast to the dark blue body!
:link: http://corvaircenter.com/phorum/read.php?1,823034
BLACKBOX HP - WB-15 FOR CORVAIR
:link: http://www.racersrods.com/product-p/wb-15-corvair.htm
:link: http://www.wiringharness.com/
M&H Electric Fabricators - Corvair Electrical Catalog - 2016.pdf
(849.15 KiB) Downloaded 31 times
:link: https://www.ronfrancis.com/
2017 Ron Francis Wiring Catalog.pdf
(16.32 MiB) Downloaded 28 times
Performance Corvair
:link: https://www.perfvair.com/stinger-ignition-distributors/
(A modern and economical alternative to rebuilding the 50+ year old Corvair distributor and upgrading it with a breakerless electronic ignition system from Crane Cams (optical trigger) or Pertronix (magnetic trigger) http://www.corvair.com/user-cgi/catalog ... IN&page=74).
Six pages of Corvair wiring harnesses and associated hardware...
:link: http://www.corvair.com/user-cgi/catalog ... graygo.y=0
:chevy:
1965 Corvair Chassis Shop Manual - SECTION 6Y - ENGINE ELECTRICAL.pdf
(8.51 MiB) Downloaded 27 times
1965 Corvair Chassis Shop Manual - SECTION 12 - CHASSIS ELECTRICAL.pdf
(6.99 MiB) Downloaded 50 times
toms73novass
Post by toms73novass »
I too love your color choice!
DeadHorse
Post by DeadHorse »
acarlson wrote:Not sure what wiring you're thinking of upgrading, but for a replacement fuse panel you might consider these:
http://www.corvairforum.com/forum/viewt ... 80&t=13427
http://www.corvairforum.com/forum/viewt ... 80&t=13481
Alec
Alec,
Thanks this is what I am needing to start with. Is Clark’s the best place to get the wiring harness? And I will call the mfg but if you know the difference between the led and non-led version.
Apittslife
Post by Apittslife »
LED version would be used if you are going to use LED lights in your car, as the Blinker relays for them are different vs Conventional Bulbs. The wiring its self should be the same.
