66 Convertible Rescue
Got a Body Tag that needs decoding? Post it here.
rv6aaviator
Post by rv6aaviator »
Gents,
Cincinnati Corvair Club rescued a 66 Convertible this weekend. A new member recently inherited the car. Some history on the car is that it is a one owner, 45K miles, 110 hp /auto, black interior & top. Car has not been on the road since 1979. One of the best rust free cars I've seen. Interior, top, engine compartment and under carriage are all in fantastic shape. Body panels are rougher than two nights in jail. Every body panel except the truck lid are covered in dents, dings and scrapes. We pulled it out into the sunshine for the first time since 1979. Car will be saved, gone through and restored as required.
Can I get some help decoding the body tag?
Thanks.
Jeff Sandor
Prez Cincinnati Corvair Club
62 Convertible
63 Spyder Convertible
64 Spyder Convertible
66 Corsa 140 Coupe
66 Monza Coupe
Re: 66 Convertible Rescue
BODY TAG INFO:
11C
Body Build Date: 11 = November, C = Third Week
The first two digits are numbers 01 through 12, indicating the month of manufacture. The letter is A-E, indicating the week of the month. The letter "C" it indicates the third week of the month.
Interior paint code: E = Black
66-10567 WRN 2735 BODY
Style: 66 = 1966 10567: 1 = Chevrolet, 05 = Monza, 67 = 2-Door Convertible 4-Passenger,
WRN = Willow Run, Michigan, Production Sequence No: 2735
1966 Chevrolet Corvair Monza 2-Door Convertible - 4 Passenger, Total Production: 10,345
TRim: 758- = BLACK (MONZA 10500 and CORSA 10700 SERIES — Bucket Front Seats)
Paint: Y-2 = YELLOW "Lemonwood Yellow"
Top Color Code - 1966: 2 = Black
Lucite No. 4709L, Rinshed-Mason No. A1824, Ditzler No. DDL 81528
Example — 1966 Corvair Monza Convertible in Lemonwood Yellow with Black Interior
ACC = Accessory line
W2M
The Letters are listed in groups. Letters following a number are in that group.
1st Group
W = RPO A02 Glass, Tinted Windshield only
2nd Group
M = RPO M35 Powerglide Automatic
Here is a sample of the VIN tag on your car, and an explanation of the tag number structure. The last six digits would be your car's unique serial number...
105676Wnnnnnn
1966 Chevrolet Corvair Monza 2-Door Convertible from the Willow Run, Michigan plant, S/N: ???????
VIN - LM Corvair Passenger Car VIN Tag Decoding
I have attached a copy of the 1966 Chevrolet Corvair GM Heritage Center Specs for your model year Corvair.
1966-Chevrolet-Corvair - GM Heritage Center Specs.pdf
(1.78 MiB) Downloaded 27 times
:chevy:
64powerglide
Post by 64powerglide »
Brad,
Would the 11 C on the tag mean it was built in November of 1965????
64powerglide wrote:Would the 11 C on the tag mean it was built in November of 1965????
Since each model year began its release around September of the previous calendar year, the 1966 model would have hit the showrooms in September 1965. So 11C on a 1966 Corvair production run would have to have been produced in the third week of November, 1965.
rv6aaviator
Progress Update
1. New Clark's Ultimate fuel tank installed
2. New dual master cylinder going in
3. New complete brake line install
4. New complete brake shoes and hardware
5. Carbs removed for rebuild and engine clean up
Car is really rust free on the undercarriage. Very nice not having to cut off rusty bolts. Compression test performed and everything is 170+. Going to finish brake work up, rebuild carbs, clean up engine compartment, reseal the engine and get it running.
Here's some pictures
Jeff Sandor
62 Convertible
66 Corsa 140 Coupe
66 Monza Coupe
Return to “Body/VIN Tag Decoding”
