Passenger side outside mirror location '65 to '69.
1965 to 1969 PASSENGER OUTSIDE MIRROR LOCATION.
I now have a N.O.S. Right mirror, but no template came with the mirror.
For those of you who have a factory right outside mirror, how far is the distance from the leading edge of the mirror base to the door / fender gap ?
Thanks.
Thanks.
Bob G., Hendersonville, NC.
1951 Chevy Styleline Deluxe 2 door sedan. 6/2000.
1969 Corvair 500 Coupe # 2671. 7/2017.
Re: Passenger side outside mirror location '65 to '69.
Yes, your pic does help. Thank you.Folgers57 wrote: ↑Thu Sep 14, 2017 2:34 pm Hope this helps
In that position, is your visibility good from drivers seat ?
I do see you have good clearance from vent glass.
It looks identical to my 65. Visibility was terrible until I put seat track extenders on it pushing seat back. It still isn't great.
Frank Metasavage
66 Corsa 140 4 speed Stock
Typically left and right side mirrors have identical mounting points as does my 65 Corsa convert
Thanks for your info.skipvair wrote: ↑Fri Sep 15, 2017 6:01 pm It looks identical to my 65. Visibility was terrible until I put seat track extenders on it pushing seat back. It still isn't great.
I understood the right mirror was set further FORWARD, but that would interfere with the wing window operation.Spike65 wrote: ↑Sat Sep 16, 2017 12:47 pm Typically left and right side mirrors have identical mounting points as does my 65 Corsa convert
Folgers57 wrote: ↑Sun Sep 17, 2017 7:13 am Works good for me, haven't had any issues.
Thanks, Folgers57.
The attached 1965 Corvair Assembly Manual - OUTSIDE REAR VIEW MIRROR section describes the left-side installation for both the regular and remote control mirror on the 1965 Corvair. I did not find anything for the passenger side, but the pictures would seem to show an identical location in relation with the window wing frame as a reference.
- 1965 Corvair Assembly Manual - OUTSIDE REAR VIEW MIRROR.pdf
- (726.69 KiB) Downloaded 32 times
Thanks Brad, info is appreciated.
- emceebrooks
Brad (or anyone),
I was looking for information on the Passenger side mirror option for EM's. Was that even a factory option, and if not, any ideas about mounting one to an EM convertible? Thanks! Marcus
Marcus Brooks
Columbus, OH / Orlando, FL
'64 Monza Convertible
