Could someone please post a picture of the circuit breaker on a '66 convert with a power top. I need to confirm how it is mounted and wired.
Also, a picture of the location of the hole in the rear shelf where the wires for the power top motor are routed.
'66 Power Top
Re: '66 Power Top
The attached sections of the 1966 Fisher Body Service Manual may be helpful.
viewtopic.php?f=225&t=6007
- 1966 Fisher Body Service Manual - ELECTRIC FOLDING TOP - CORVAIR.pdf
- (722.15 KiB) Downloaded 25 times
- 1966 Fisher Body Service Manual - FOLDING TOP.pdf
- (12.71 MiB) Downloaded 27 times
Re: '66 Power Top
Thanks Brad. In Fig. 11-73 of the Electric Folding Top section, it looks like the 10Ga red from the wiring harness screws to the engine rail using the red plastic stand-off as usual. Then a short jumper from there to the battery side of the relay. There is one other wire in the diagram from the red stand-off but it does not go anywhere. Any idea what that wire is?
Would anyone have a template showing the hole location for the motor wiring to pass through the rear shelf?
Re: '66 Power Top
Here's the relevant page from the assembly manual. Note the reference to dimples marking the installation location for the circuit breaker. The power top "power wire" goes through an existing grommet in the engine compartment.
