First Nissian SR20 (Na to turbo)powered Corvair
Corvairant
Re: First Nissian SR20 (Na to turbo)powered Corvair
Post by Corvairant »
63 mph at 3500 rpm
Corvairant
500rpm and 3mph difference
Corvairant
Started the process of putting radiator in front of car
Corvairant
Front seats are pretty close to being done
Corvairant
Won first trophy for car ..."Rat Rod"
Corvairant
More pics of some progress
Corvairant
And I wanted to give a shout out to Steve Goodman form Rear engine specialist for rebuilding my rear wheel bearings
Corvairant
Corvairant
Here is a few more recent pictures
Corvairant
Probably have 700 miles recently put on car !
Made it to El sagundo , Ca.for Ageless to Anarchy and
Palm Springs for the Fanbelt Toss
Corvairant
chris
Post by chris »
How’s it doing with the new radiator setup?
Corvairant
Been off sight for awhile
Chris it's cooling good so far , been adding turbo to engine
Corvairant
More pics of progress
Glade to see the car is coming along. Enjoyed seeing it at the last SCC show.
Are you going to make the Rainbow Meet north of San Diego?
Corvairant
I will try my best to be there 🤙😎
Lots of small stuff to get finished/ or working
Ecu is on way back from tuner
Injectors are back in after I had bad o rings
Added wideband gauge and moved aftermarket tach
To stock cluster
