LM rear coil spring specs
Roelof
Post by Roelof »
Hi,
I am looking for the factory specifications for the stock rear coil springs of a '66 monza convertible.
Clarks is out at the moment so I want to try to find someone on his side of the atlantic that can reproduce them for a reasonable price. And corvairs are not common here.
Roelof
The Netherlands
Re: LM rear coil spring specs
Some of the 1966 suspension specifications — including the front and rear spring specifications — can be found in the attached 1966-Chevrolet-Corvair - GM Heritage Center Specs, beginning on page 21.
1966-Chevrolet-Corvair - GM Heritage Center Specs.pdf
(1.78 MiB) Downloaded 184 times
Hard top: 7688 and 9201 (Reference "A" in each spring specification table)
Convertible 7690 and 9202 (Reference "B" in each spring specification table)
Identifying Springs?
:link: http://corvaircenter.com/phorum/read.ph ... 767,542827
Here is another coil spring source that can provide Corvair springs, but they are also located in the USA...
ImageI suspect this source could build Corvair springs that would be properly calibrated to produce desired support and body height. They would be familiar with spring design, so that correct materials and other parameters could be chosen to result in a safe design that would produce needed support, fitment, and ride height. Just click on "Request a Quote" and dial in the information about your car, including desired ride height adjustments and lowering...
Antique / Hot Rod Coil Springs
These symbols of yesterday can be found getting a new life for the road in garages all across the world. Although most are being restored to their original condition, many are after a specific look, such as the gasser look of the race track or the slow and low easy rider of Main Street. Whatever your goal, Coil Spring Specialties has the expertise to set your project vehicle at your desired height. And don't over look weight changes. These changes can significantly change the load dynamics and trim height of your vehicle. So if you gain or lose a few pounds due to engine swaps or chassis and body modifications, we can compensate for these changes with a new pair of springs.
Whatever the make or model, from classic collectibles to muscle cars, show-stopping originals to clones, we have supplied auto enthusiasts with coil springs, all 100% calibrated to fulfill their suspension needs.
We build each set of springs to your vehicle's specifications. We will need YEAR, MAKE, MODEL, ENGINE SIZE, TRANSMISSION TYPE, and A/C to put into account for each car we engineer for, as all these options play into the manufacturing of your springs
:link: http://www.coilsprings.com/classic.aspx
Call (785) 437-2025
Roelof
Post by Roelof »
Thanks for the very complete reply.
I don't know if the info on the specification sheet is enough to reproduce the springs. I'll ask around.
I already found coil spring specialities as it was recommended somewhere on the forums. They gave me a very reasonable quote. I did not get a shipping quote yet. But as usually, as a rule of the thumb, the shipping this whay is more or less the price of the part itself, I thought that if I would have them reproduced anyway I also could try to find someone on this side of the pond.
But It will be hard to find someone with corvair experience here. So l might order with coilspring specialities anyway.
