Strapping down to a flat bed
frez
Post by frez »
Hi everyone
Tomorrow morning I am strapping my 65 convertible to an auto flat bed. From what I am reading on line 4 straps crossed or not back is looped around the rear strut rods and the front is looped around the lower control arm. Does that sound right to you?
65 Monza Convertible converted to CORSA with a 1966 180hp turbo
cnicol
Re: Strapping down to a flat bed
Post by cnicol »
Yes, that's about right. If you decide to cross the rear (more secure on rough road surfaces), place your tie-back loops near the differential. (They'll slide to the center and loosen if you start with them tied outboard.)
frez
Post by frez »
cnicol wrote:Yes, that's about right. If you decide to cross the rear (more secure on rough road surfaces), place your tie-back loops near the differential. (They'll slide to the center and loosen if you start with them tied outboard.)
Thanks much all worked well and got it to Gettysburg pa in one piece.
cnicol
Post by cnicol »
:tu:
