I'll assume the guy that had them before me drilled them.
I heard they need drilling for stock...and I'm running 1/2"X20 studs.
These could also be off the buick wildcat of that era. That is what I have on rear of my 66 coupe and 78-80 buick/chev malibu station wagon aluminum rear drums on the front of the 66. They both have the "visual" fins and work well for drum brakes. Just a thought. My 66 has a built counter-rotating buick 215 in the rear hooked to a HD PG with a 4 spider posi differential. It does have 16" IROC wheels now and also used 14" front and 15" rear rally wheels prior to the IROC wheels, so I know these clear the drums with no problem - however I never tried them with 13" wheels relative to clearance. Hope this helps.65Ragtop wrote:Hello Phil and anyone else out there who reads this. Are these Buick GS front drums circa 68-72? For some reason they don't look like it to me but I have not seen any for many years. I could be wrong. I've been looking for some for awhile now and they seem to be a kin to the proverbial hens teeth. What I was really wishing was that there was another doner source I did not know about. Any info would be cool. I have several sets of the front finned aluminum drums and would like to match the rears.
I will go to finned cast iron if I don't come across some eventually. Anybody out there got any info on good sources for these? I can find new finned iron replacements for the GS items and can machine to fit. I am just trying to widen my horizons here. Options are good. Thanks.
Thanks for the complement and good hunting!65Ragtop wrote:Thanks for the info. I am always on the lookout for some good finned aluminum drums, locally. I am a bit of a junkyard phantom.Front ones seem fairly common but the rear ones are a challenge. I did mangage to find some thanks to a forum member. Your car sounds like a great ride.
