Weber upgrade advise and build thread
72BBNova
Re: Weber upgrade advise and build thread
Post by 72BBNova »
I got my modified air cleaner back today from the chrome shop. Very pleased with the finish, it's hard to believe that this thing is 50 years old. Jeff
Before
After
Jeff
1964 Spyder coupe
1966 Corsa convertible (project, some assembly required)
1972 Nova 496/6spd
1975 Chevy Cheyenne 454 C20 camper special
72BBNova
Post by 72BBNova »
I got my alcohol/meth tank back today. I still need to have a couple openings put in. I plan on painting it yellow to match the engine compartment. I'm going to use a Turbo Start battery on the tank. Jeff
Jeff
1964 Spyder coupe
1972 Nova 496/6spd
miniman82
Post by miniman82 »
Damn that thing is clean.
Click it!
happydaze
Post by happydaze »
Such a great post! I had all the same questions. The one piece I am missing in the info provided is what lb rating am looking for in a wastegate? I have the exact setup as the OP. 10lb? I wasn't planning on running bug juice.. but if it is hugely helpful and requires tapping in a basic nossle maybe. What is the upper bung tapped for in the original picture? o2 sensor that works with the electronic timing??
I can teach anyone willing to learn the wrong way to do anything!
Brian
63 Spyder Coupe
64 Olds Convertible LS2
Bunch of other stuff that doesn't matter
72BBNova
Post by 72BBNova »
happydaze wrote:Such a great post! I had all the same questions. The one piece I am missing in the info provided is what lb rating am looking for in a wastegate? I have the exact setup as the OP. 10lb? I wasn't planning on running bug juice.. but if it is hugely helpful and requires tapping in a basic nossle maybe. What is the upper bung tapped for in the original picture? o2 sensor that works with the electronic timing??
Brian, from what I understand on the wastegate's they come with different spring rates for different pressures, you can change your pressure just by changing the spring "I think". As for the nozzle I'm going to have an 1/8" pipe thread bung welded in on the turbo housing. The O2 sensor is for a wideband to measure the air/fuel ratio for tuning the carb. Jeff
Wideband sensor I have, http://www.innovatemotorsports.com/products/db.php" onclick="window.open(this.href);return false;
Jeff
1964 Spyder coupe
1972 Nova 496/6spd
miniman82
Post by miniman82 »
Uh-o, LC-2 schlockiness....
Ask anyone who's had one for a while, I haven't met one yet who would buy another. At least, not with their own money! lol
Click it!
notched
Post by notched »
I have an LC2 on my car and it has been great. I have put over 2k miles on it with no issues and I drive my car hard. Everyone is entitled to their opinions.
AEM and Autometer and FAST all have wide band kits now so you do not have to stick with one brand. There are also DIY kits as described on the old DIY EFI site.
1966 Corsa turbo
1969 Monza convertible
1987 Buick Grand National
notched
Post by notched »
Depending on whose waste gate you buy will determine whether it will come with springs. Turbonetics will not. I have a Tial MVR 44 on my car and it comes with a large assortment of springs. I just helped install a pair of Precisions on a Porsche 996 turbo today and they too come with the springs. I edited this to correct previous info.
1966 Corsa turbo
Scott V
Post by Scott V »
miniman82 wrote:Uh-o, LC-2 schlockiness....
everyone i asked - liked them & had good things to say about them. i bought a lc-2 & it works fine. so does my lc-1, lma-3 & xd-16.
-Scott V.
happydaze
Post by happydaze »
Notched - guess my last question didn't post. Do you know how that slip joint was made? Just using a pipe expander I hope and use like a 3" overlap?
Brian
63 Spyder Coupe
notched
Post by notched »
We did it using different ID to OD pipe. But you could use a pipe expander. The fit on mine is pretty tight at ambient temperature. You have to work the pipes together and apart. When they are hot you won't be able to budge them so you definitely want to make sure they are not falling apart loose.
1966 Corsa turbo
Alexrobic604
Post by Alexrobic604 »
I'm building a air cleaner like you did, but I doubt it will be as nice as yours. I was wondering where you got the tubes from.
Regards Alex
62 Corvair Monza 900 Convertible
72BBNova
Post by 72BBNova »
Alexrobic604 wrote:I'm building a air cleaner like you did, but I doubt it will be as nice as yours. I was wondering where you got the tubes from.
Regards Alex
I bought them from Carbs Unlimited here's the link,
http://www.carburetion.com/Products/Pro ... rt=CU40-26" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Jeff
1964 Spyder coupe
1972 Nova 496/6spd
turnert7696
Post by turnert7696 »
This will be a very valuable thread if I decide to build my turbo engine instead of selling it.
