Here is an example of the process...Since none of the big wheel and tire retailers know anything about Corvairs , the Corvair owner has to do the research and calculations to tell the retailer what the Corvair needs. Careful research is needed so you don't end up with any "surprises" when the tires and wheels arrive. They can be difficult to return or exchange if they don't fit -- especially when the sizing choices were made by you and not based on a salesman's recommendations! Salesmen and retailer technical "experts" can tell you about quality, warranties, sale pricing specials, and general road performance characteristics, but they cannot tell you about non-standard sizing for your Corvair.
Actually, the database on tires and wheels on the Tire Rack website is extremely useful, once you determine several critical factors, including:
WHEELS
1. Diameter
2. Width
3. Backspacing
4. Lug Pattern
TIRES
1. Rim Diameter *
2. Rim Width *
3. Desired Overall Outside Diameter **
4. Calculated Revs per Mile **
* Tires sized to meet selected wheel specifications
** Aspect ratio and tire profile selected to maintain correct operation with Corvair differential final drive ratio and speedometer accuracy requirements. This information can be found for each tire in the Tire Rack online database.
Use the information on the following website to determine the desired wheel and tire sizing for your Corvair.
SIZING CORVAIR WHEELS AND TIRES
Then use the data on the Tire Rack online database to select your wheels that meet your Corvair's needs and your styling and pricing preferences. Finally select tires to match your Corvair's needs, selected wheel sizing, and your preferences for tire handling, weather, and wear performance and pricing. Now you have the desired wheels and tires that match each other and your Corvair's technical needs too.
http://www.tirerack.com
The Tire Rack database can help you to select proper wheels and tires to match the above parameters. Their consumer feedback and tire reviews can help you to select performance, pricing, wear performance, etc. to meet your desired expectations and driving habits.
My Current tire sizes on my 1966 Corsa are:
Current Tire Product and Size:
Front: Goodyear Eagle ST P195/70 R14
Overall Diameter: 24.8" Revs per Mile: 839
Rear: Goodyear Eagle ST P235/60 R14
Overall Diameter: 25.1" Revs per Mile: 829
I found the Overall Diameter and Revs per Mile numbers on the Tire Rack by selecting my current tire sizes, and then looking them up on current Tire Rack listings...
Next, I chose some wheels I might be interested in. In this example, I started with wheels offered for a car that could be a GM donor vehicle for a LM Corvair -- a Pontiac Firebird. I chose a 17x7" or 17x8" rim in this example that had the correct lug bolt pattern of 5 lug 4 3/4" (5-475) and wheel backspacing or 4" to 5"
The Tire Rack recommended tire size for these wheels was 2.45/45-17, but I discovered that this size has Overall Diameter and Revs per Mile numbers that were too high for my Corvair, so I looked at other sizes that were similar to the size recommended by Tire Rack for these wheels, but also closer to the specs needed by my Corvair. A good compromise size is seen below.
REAR WHEEL AND TIRE SELECTION
The 2.25/45ZR-17 has an overall diameter of 25", which is very close to the 25.1" overall diameter of my current 14" rear tires. 833 Revs per Mile is also very close to my current rear tires, which provide 829 Revs per Mile. The Michelin tires in this size will also tolerate a 7" to 8½" rim width, so this tire would work on my Corvair rear using either a 17x7" or 17x8" wheel which gives me 4.02" or 4.52" backspacing (also in the desired range for my Corvair).
FRONT WHEEL AND TIRE SELECTION
The 2.15/45ZR-17 has a slightly smaller overall diameter of 24.7", which is close to my current 14" front tire overall diameter of 24.8". 844 Revs per Mile is also close to my current front tires, which provide 839 Revs per Mile. This will help with body clearance and speedometer accuracy on the front of the LM Corvair. These Michelin tires in this size will also tolerate 7-8" rim width, according to the Tire Rack chart, so they will fit on the selected rims in either 7" or 8" widths.
FINAL CHOICE?
A conservative choice would be to use the smaller 2.15/45ZR-17 tires all around, mounted on the narrower 17x7" wheels. This provides 4.02" backspacing and are less-likely to be problematic than the wider 8" wheels or the slightly larger tires in the final installation. The larger sizes would likely fit OK on the rear of the 1966 Corvair, but doing so eliminates the possibility of tire rotation to promote more-even tire wear.
Alternately, the 8" wide wheels might work all around, with the wider tires on the rear, or the smaller tires all around to permit tire rotation. The 8" wide wheels have about ½ inch more backspacing, which seems to be the "sweet spot" to promote better steering feel and clearance. But care must be taken when fitting these more extreme wheels and tire sizes to avoid body or suspension interference problems. Some body modifications or suspension mods might be necessary.
Tire and wheel sizing for your Corvair can be a somewhat long and tedious process. If you find another Corvair owner who has similar wheels with the same diameter, backspacing and rim width, you can safely duplicate that person's Corvair wheel and tire sizing on your own Corvair, if your car is the same model year series and has similar suspension characteristics. Otherwise you will need to do your own careful numbers crunching to find the right wheel and tire combination in 14", 15", 16", or 17" sizes for your Corvair.
Some aspirin or Tylenol might also help.
