VOTE- Corvair of the Month May 2014
Re: ENTER- Corvair of the Month May 2014
I'm entering my 64 Spyder Convertible in COM.
Just now has 77777 miles on it!
1949 Ford 8N Tractor
- ihscomputers
- Corvair of the Year
Since it's unlikely that my Rampy will win for April 2014, I am submitting my entry for May:
1962 Corvair 95 Rampside
The previous owner was one of three friends who bought the shell and completed the resto-mod in 1986, spending over $30,000 in the process.
As purchased:
95HP with 4 speed
Custom-made aluminum dash gauge pod with Stewart-Warner gauges
Power antenna that rises from the just behind the driver inside the edge of the bed
American Racing Outlaw II wheels and 14" radials
Bedliner applied to the lower bed and ramp
Very loud air horn
Chrome vent visor window shades
Engine cover converted to hinged cover with prop rod
Large "truck style" reverse lights with dash-mounted switch
Fog lights with dash-mounted switch
My mods:
Front disk brakes
Lowered front end just a bit
New inside wheel well trim
New carpet
Added arm rests
Replaced old failing Pioneer AM/FM/Cassette stereo with Sony AM/FM/SiriusXM/USB stereo and new speakers
Installed 3 point seat belts
Sliding rear window
As purchased:
95HP with 4 speed
Very loud air horn
My mods:
Front disk brakes
New carpet
Added arm rests
Sliding rear window
Dean F. Gemberling
Box Springs, Georgia
Heart of Georgia Webmaster
Director-elect for Eastern Div
1965 Monza Coupe w/63 Buick 215 V8 - Former 13-sec Drag Car by Ken Arnold
This is my 61 Monza Coupe. I bought it in Sept. 2012 and it was drivable but had body damage and rust and the interior was a goner. Lots of help from you guys and a year and a half later I think I'm ready to try for COTM.
Now that the paint is finally done I can focus on the interior. I got a complete set from Clarks and redid the seats and doors. I primed and sealed the entire floor with bed coating brushed on and sprayed undercoating in the inner panels. I also cleaned up the reusable chrome and repainted the colored parts of the badges. Now it looks like this. All work was done by be except the paint spraying and the covering of the front seats. The engine is not painted yet but since I now have to pull it out to replace the clutch family I will be totally cleaning and repainting it. It has been quite an enjoyable but busy journey...and worth every minute and dollar.
1961 Monza
Interior pics for Bigtwin's Monza
I ran out of space for pics but had to show a few of the inside, I hope you don't mind.
This is it guys, I hope you like it as much as I do.1961 Monza
- Fast Eddie
Well, so much for April. Lets give May a shot. Once again, good luck to all.
Original owned 1966 Corvair. Engine, Basic 140 hp modified to approximate Yenko Stinger Stage II output. Approximately 200+ hp, 10.1 compression ratio. Heads fitted with deep valve seats. Roller rockers, crank, stock 140 polished & balanced. Cam, Iskederian 260/.050 duration. TRW forged pistons. 3.55:1 differential. Four primary carburetors, chokes removed, direct linkage, re-jetted and vented. Flywheel stock Corvair, welded. Exhaust, stock 140 for street & heat. Suspension, Front 3/4" anti-sway bar, heavy duty springs one coil cut, stock box with EICO short arms. Shocks, KBY.
- Fast Eddie
Re: VOTE- Corvair of the Month May 2014
Wow! I had the lead for one hot second, then ihscomputers came roaring back! That Rampy is one tough customer!
- Crazy George
Still alive and kicking, told Scott had to get on to check out what we have and cast a vote you guys have done allot of worked to these car for sure. every month it is tough but if you don't get this month be sure to put in the next . this is a tough, but can't vote all, so its got to be one vote.. You know that I am more of of a late model vair person but I have to give it to Ihscomputers. I know you guys worked so hard and sweat on these treasures but this Rampy stuck out to me.. good luck all ! CG
The competition was pretty tough recently, but you finally took your well-deserved place of honor!
- ihscomputers
A hearty shout-out to Skrain, BIGTWIN and Fast Eddie for the well-fought competition this month!
I'd also like to thank my producer, my agent, my entourage, my wife, my son, my two dogs and all of my adoring fans!
Good luck to each of the entrants for June COTM 2014. May the best vehicle and owner win!
Dean F. Gemberling
- Fast Eddie
Congratulations on a well deserved win. Skrain, BIGTWIN & I thank the folks that voted for us, but there was no catching you this time.
You da man! I'll be back. I don't mind losing to that one, I almost voted for it myself. Congratulations.
1961 Monza
Here is an extracted article from the July-August 2014 CORSA Communiqué. The article covers the May 2014 winner of the Corvair of the Month...
The Juicy Life of Mr. Citrus
Left-click on each image to enlarge for better viewing... I have attached a copy of this article in Adobe Reader (.pdf) format...
- COTM May 2014 - Communique - 2014 July-August - Vol 36 - No 6.pdf
- (725.2 KiB) Downloaded 57 times
- 72BBNova
When I read that article I remembered that truck. I was a member of the Circle City Corvair club then and that's when The Hoosier Auto Show was held at the Indianapolis Motor Speedway. There would be 120+ Corvairs at that show every year, a huge event. That truck was really nice and had a lot of money put into it. Jeff
Jeff
1964 Spyder coupe
1966 Corsa convertible (project, some assembly required)
1972 Nova 496/6spd
1975 Chevy Cheyenne 454 C20 camper special
1964 Spyder coupe
1972 Nova 496/6spd
- ihscomputers
Thanks for posting that article, Brad!
...and for you sharing your memories, Jeff!
Dean F. Gemberling
