Seat belts
Seat belts
Okay so as I've been advertising; the coupe will be daily driven.
I've got two girls who would ride in the back and require real belts.
In addition shoulder harnesses up front would be cool as well.
Whatever I end up using though, needs to not look like crap once it's installed.
Ideas?
IRa
Ideas?
IRa
Re: Seat belts
I saw a drawing awhile ago, I'm pretty sure I saved it lemme go look.
Re: Seat belts
Found it, I think?
well sorta, its convertible shoulder straps and belts. Maybe it will help some.
Seat Belt install Late model
- lmseatbeltinstallp1.pdf
- (179.63 KiB) Downloaded 412 times
- lmseatbeltinstallp2.pdf
- (162.58 KiB) Downloaded 255 times
Re: Seat belts
Here's what I did. http://www.persh.org/Corvairs/seatbelts.htm
Re: Seat belts
Nearly indentical to how I have done 3 point front belts on late models , except I have always been painting the car anyway so I weld in the anchor. When using a retractable belt I often weld a new anchor in the inner rocker panel as well, as far back as possible to allow for easier rear seat access.persh wrote:Here's what I did. http://www.persh.org/Corvairs/seatbelts.htm
Your car could have the shoulder harness anchors already in place assuming it is the 66 CORSA. 65's do not have them and as far as I know early production 66's may not either. Certainly some late production 66's have them as I have used some.
The slick way to do the rear anchors if needed (your car should have them) is find a junk and get the reinforcement plates out of the floor. This junk could be a later Corvair or other GM, or even maybe a Honda. Most cars use a formed steel reinforcement plate at each anchor point. Cutting some of these from a junk and then welding them into the Vair makes a clean safe anchor point install (get the seatbelt mounting bolt while your at it, thread sizes may vary).
Nice seatbelts can be had from numerous sources. I have used Juliano's Interior Products
http://www.julianos.com and have been happy with the service and products
Re: Seat belts
Well... it's been over a month since I originally posted that.... and in that month I've done some research.
I've decided to kick it retro with a set of four- three point non retractable harnesses from Wesco Performance.
So far I haven't been able to dig up any dirt on Wesco, which is good, so unless anyone has a reason... I'll give them a shot.
I'm going with non retractables to save on weight (I know, I know... it sounds silly but I'm not putting a stereo in it for the same reasons) and the style is a throwback to the mid 60s and early 70s.
As far as mounting is concerned, I've got plans for custom mounts in the rear... the fronts are a no brainer.
Today is supposed to be 78 and tomorrow is supposed to be near 80... so I should be able to get a whole bunch of stuff done on the coupe this weekend!
Once again thanks for the help guys!
Ira
Ira
Re: Seat belts
The biggest problem with the non-retractable harnesses is that when adjusted properly, you can't reach stuff on the dash (I have them on my '73 Nova and '69 Corvair).
Dave Keillor
Rochester, MN
Rochester, MN
Re: Seat belts
Yeah...
Our Alfetta GT was originally a race car back in the day.... so I can attest that a four point harness is much worse .
In this case it shouldn't be much of a problem based on where I'll have my seat positioned.
But yeah.... I'm with you.
IRa
IRa
Re: Seat belts
I'm planning to use the Schroth Autocontrol harnesses in my '65 restomod. It has a lockable intertia reel. Interestingly, my objective for the restomod is a GT car in the spirit of the GTV.
The '73 Nova and '69 Vair have the factory standard separate harness belt which is a pain to buckle as well as wear.
Dave Keillor
Rochester, MN
Rochester, MN
Re: Seat belts
So when you say GTV.... I'm assuming that you're not referring to a GTV-6.... but an early GTV... say 1969ish?
I would love to own one but I doubt that'll ever happen.
Yeah.... the GTVs were the ultimate saloon car back in the day. People forget that prior to being owned by FIAT... Alfa had no problem winning races. Unfortunately Alfa is now overshadowed by Ferrari and Maserati.... for whatever reason.... Fiat wants it that way. Now most of the Alfa stable is dominated by front wheel drive models.... and I promise I will never own a vehicle that drags itself around by its front axles.
Ira
Ira
Re: Seat belts
HAS ANYONE HAD ANY EXPERIENCE WITH SHOULDER HARNESS'S IN THE BACK SEAT? ALSO WHAT ABOUT HAVING A PAIR ON A BENCH SEAT?
Wife and kids or a Porsche??? Well I got a corvair and the family... best of both worlds!!
