Stock spare tire rim size question:
I just took off all the old rotting 4 ply poly tires off of the rims that were on my 65 Corsa. I noticed that the spare rim was much narrower than the 4 others. See pic. Is this a stock configuration or did someone slip a non standard spare in while nobody was looking? The car was 99% stock when I drug it home....so I was just wondering. I am going to refurbish the rims so I would like to know. Thanks. ![chevy :chevy:](./images/smilies/chevybowtie.gif)
Mike S.
65 Corsa 140 Ragtop
CORSA member
65 Corsa 140 Ragtop
CORSA member
Re: Stock spare tire rim size question:
I have never seen a narrower spare rim in a Vair (stock non space-saver that is...some have put later space savers in there). Standard spare is a regular rim with a full size tire.
how wide are the 4 wheels you pulled off the car? they look alot wider than a stock 5.5".
-Scott V.
-Scott V.
Hello Scott. It is an optical illusion, they are 5.5" rims. The spare is a 4.0" rim. I thought the same thing when I first looked at the picture.
Thanks Ted. I also have not seen (but must admit I never looked all that close) a thinner rim for a spare on a Corvair. I thought I would include another pic to show that the rims are for sure related at least (GM) as the construction is identical except for the width.![think :think:](./images/smilies/think.gif)
Mike S.
65 Corsa 140 Ragtop
CORSA member
65 Corsa 140 Ragtop
CORSA member
I think some one swapped in a narrower rim for some reason on the spare (mixed spares up perhaps or had a flat spare and that one replaced it?).
Possibly a chevy II 5 bolt .
I think your right Ted. I was also thinking Chevy II as well "-hotrod". Thanks for the input. I will ask around a bit more and If I hear anything different I will post it. For now, it's a swapped out Chevy II rim as far as I'm concerned....
The more I think about it, I kinda like it anyway. The thin rim weighs in at 3.2 lbs. lighter than the stocker. It looks stock and any weight reduction rear of the transaxle can't hurt.
Mike S.
65 Corsa 140 Ragtop
CORSA member
65 Corsa 140 Ragtop
CORSA member
I mount my spare in the trunk:)
I usually do as well Ted. This time I am looking at a stock like restoration. Not sure I have the discipline to pull it off however! I can't help lean toward some sort of improvement or mod.
Wish me luck, eh!!! ![cool :cool:](./images/smilies/glasses2.gif)
Mike S.
65 Corsa 140 Ragtop
CORSA member
65 Corsa 140 Ragtop
CORSA member
I have done that type car as well:)
