Coil install
Corvair1
Coil install
Post by Corvair1 »
Hi Fellows, I have to install a new coil for my electronic ignition and I can't remember how the wires from my harness are hooked up. I have a brown and yellow hooked together and a white which has power.
Thanks
Herb (Corvair1)
Alexandria, Ontario
Canada
Website:http://corvairone.com/
Re: Coil install
The power lead goes to the positive (+) terminal, and the brown lead (tachometer) and the short lead from the distributor breaker plate (points) connect to the negative (-) coil terminal. This should help...
