Praise the lowered...!
- atwistedgrip
Pic of my recently lowered '62 Greenbrier. Thanks Mike.
- '62.jpg (95.87 KiB) Viewed 5091 times
Re: Praise the lowered...!
Lookin' good! You driving it to the next meeting?
- atwistedgrip
That's the plan
I like FCs but have only ridden in one once.
Some Flower Power decals and it would be a perfect "Hippie-Van"
Any plans to autocross it ?
- 63aq4657n.jpg (42.33 KiB) Viewed 5062 times
Take some measurements off of the front and back, I will do the same, be interested to see where it sets. Anyone with a stock height van or pickup let us know what it is. Say off of the corner of the front and rear bumpers, from the bottom of it. Im not anywhere near as low as turbo king, but its something to shoot for, I would like to do bags for mine and lay it out as far as possible. I like the air over hydraulic setups they are doing now.
Kevin, Plainfield IL
'63 Corvan
'63 Custom Bug.
'63 Corvan
'63 Custom Bug.
The winter here in Missouri is still going strong and I have really not been able to the truck out to take some great shots.
Well the weather did clear off some, but now we are back to the crap weather here in Misery. I did manage to back my truck out and shovel out the snow in the bed but that was it before the next round of snow hit.
- atwistedgrip
Here are some pics with measurements I took this morning.
I'm not really that low, just lower than stock.
The van has a nice raked look now that I like much better than the old nose-up look.
The tires are 215/60-15, so they are about 25" tall...
The tires seem a little big now, but i haven't had any clearance issues so far.
50 series rubber would drop me down a bit more and might improve the look some but the tires on there now are very new, so I'm going to have to wait.
Lookin good!!!
Nice rake to the front.
Measured mine, not setting on level ground in the garage right now, have a drain in it.
I also cant post up pretty pics with my measurements so I will just type em out. lol.
Front bumper 12" both sides
Front wheel centers to lip 13.25" both sides
Rear bumper rt- 13.5", lt- 13"
Rear center to lip rt- 10.25, lt- 10"
Running 185/60/14's
Will be nice to measure once I pull it out onto flat ground. Almost guess the rear bumper isnt level, but cant tell for sure.
Should help give a idea of how different tire sizes will drop a vehicle also.
Doesnt realy have much camber in the rear either.
Running 185/60/14's
'63 Corvan
'63 Custom Bug.
'63 Corvan
'63 Custom Bug.
- atwistedgrip
Now that is low...!
If only my truck was a power glide I could set it on the ground.
Well you see the shifter rod "tube" that is attached from the shifter linkage to the trany on a manual FC happens to be the lowest point on the truck. Bad things can happen! I guess you could make a skid plate and let it just rub the ground all the time. This summer I will be adding a skid plate around the shifter linkage up front just in case.
- atwistedgrip
I think GM changed the shifter linkage design mid production in 1963.
I believe the later year FC's have a "tunnel" for the linkage through the gas tank.
The other FC's around me are 61's so that wont do us any good. Maybe someone can find a picture for us to compare.
