you can get a lc-1 for under $200 - that is ready to go & you dont need to build a cable.miniman82 wrote: you should still be able to get a functioning wideband with sensor for around $200 if you don't mind building the cable.
-Scott V.
Scott V wrote:you can get a lc-1 for under $200 - that is ready to go & you dont need to build a cable.miniman82 wrote: you should still be able to get a functioning wideband with sensor for around $200 if you don't mind building the cable.
-Scott V.
innovate motorsports http://www.innovatemotorsports.com/products/lc1.php makes the lc-1. i have had one for many years & it works very well. i know many others who have them & they have no problems w/it. its a quality unit from a very well respected company and it is a great value. innovate stands behind they stuff & has good customer support.cvair4life wrote:Scott V wrote:you can get a lc-1 for under $200 - that is ready to go & you dont need to build a cable.miniman82 wrote: you should still be able to get a functioning wideband with sensor for around $200 if you don't mind building the cable.
-Scott V.
Tell me more!
Scott V wrote:innovate stands behind they stuff & has good customer support.
http://www.cbperformance.com/catalog.asp?ProductID=1673miniman82 wrote:Scott V wrote:PLX has a cheap wideband for sale on the CB Performance website, maybe check that out?
the plx are nice units & have a good reputation. if my lc-1 or old lm-1 takes the dump & i wasnt going to build a kit - i would probably go w/a plx or lc-2 as you mentioned. my old motec is still running strong - expensive but built like a tank.miniman82 wrote:Scott V wrote:innovate stands behind they stuff & has good customer support.
They are, and I like them. Only question is would you rather keep on replacing an LC1 when it inevitably fails, or buy once and keep a reliable unit? By brother has been through 2 of them so far, I know of 2 others with more bad ones than I have fingers on one hand. Not bashing the product, but it's reputation is a bit substandard. PLX has a cheap wideband for sale on the CB Performance website, maybe check that out?
its probably 20 yrs old now. large machined aluminum box, liquid crystal display. cost around $3500 new. uses a lsm-11 sensor. technically not a wideband but a precision narrow band. very accurate & very helpful. nothing else was around @ that time. paid for itself even @ that cost. electronics - got to love them - the stuff gets better & better @ the same time the price goes down.miniman82 wrote:MOTEC wideband? Tell me more...
