bad oil leak 63 monza
monzadon
Post by monzadon »
i changed l my oil filter and now i am getting a lot of oil leaking on top of the motor, the filter isn't leaking, i had about 2 quarts of oil on the floor and i only ran the motor about3 seconds, i can't figure out where it is coming from, i checked the pvc and it is clear, any idea where it might be coming from sure would be appreciated, i just don't know where to look
jjohnsonjo
Re: bad oil leak 63 monza
Post by jjohnsonjo »
If its not leaking at the filter , the filter may be clogged forcing a leak elsewhere. Oil pressure switch is a known problem. Also possibly added too muck oil
kumquatbob
Post by kumquatbob »
Sorry. Try wiggling the filter to make sure it is tight. Then remove and check the gasket. There is one on the bolt, too.
Bob
monzadon
Post by monzadon »
thanks for the information, it isn't over filled with oil and it is a new filter from Clarks and it is tight, this is the second Corvair i have restored, i did a 66 with a 140 motor, i rebuilt the motor without any problems, i'll check the oil pressure switch, and maybe the new filter is bad i might need to replace it, i was told that it could be the pvc tube, i know something is plugged to make it spill out this much oil, the puzzling thing is it doesn't leak right away, it didn't leak after it was started, i went back a hour later and the oil was all over the floor
monzadon wrote: Wed Apr 09, 2025 8:18 am i changed l my oil filter and now i am getting a lot of oil leaking on top of the motor, the filter isn't leaking, i had about 2 quarts of oil on the floor and i only ran the motor about3 seconds,
That is a BIG oil leak. If it was fine before changing the filter --------- Just guessing, but I bet it is shooting oil past the filter gasket where you can't see it. Only other thought is -- did you put the plug back in the oil pan? No insult as I've done it :rolling: :rolling: :rolling: :rolling:
Wagon Master
Post by Wagon Master »
If you didn't already disgard it, look at the old filter. Are both rubber seals still on it? If so, you'll probably have to drop the newly installed filter and see what condition the gaskets are in. Have a new filter ready if needed. Sometimes you can get lucky and reinstall the new(ish) one once you find the sealing issue.
Post by Frank DuVal »
Yes, if the old filter's seal is still inside the oil filter adapter it will spew oil! Two flat rubber gaskets do not seal.... :tu:
monzadon
Post by monzadon »
i just ordered a new filter and oil pressure switch from Clarks, i'll replace both and hope it will fix my bad oil leak because the oil leak isn't small it leaks about 2 quarts
jimbrandberg
Post by jimbrandberg »
Another potential place for a big leak under pressure is the oil cooler seals but it doesn't go to the top of the engine.
Oil pressure sender isn't usually a huge leak.
A big leak should be easy to locate if you've got more oil and some floor dry.
monzadon
Post by monzadon »
i drove this car into my garage without a oil leak, it all started when i changed the oil and installed a Wen oil filter, the gasket kept popping out and not sealing so i ordered a Clarks filter where the gasket is attached to the filter, the Wen filter gasket was loose on their filter and that is why it wouldn't stay in place, the Clark filter isn't leaking
Frank DuVal wrote: Wed Apr 09, 2025 6:30 pm Yes, if the old filter's seal is still inside the oil filter adapter it will spew oil! Two flat rubber gaskets do not seal.... :tu:
Frank may be correct. Monzadon Did you check to see if the old seal is stuck in the oil filter engine housing???
Wagon Master
Good call Frank! :dontknow:
TheBusDriver
Post by TheBusDriver »
I am having this exact same problem, down to adding Lucas. I changed the oil switch and oil filter those are not leaking now. It appears to be coming from here.
American Mel
Post by American Mel »
Nothing under the top shroud should have suddenly sprung a leak just because you did an oil change.
What you likely saw was oil bubbling from cooling air escaping along that area where the top shroud connects.
Did you check your oil filter to make sure that you don't have a double gasket situation?
TheBusDriver
American Mel wrote: Fri Apr 11, 2025 5:10 pm Nothing under the top shroud should have suddenly sprung a leak just because you did an oil change.
I think this is the case. I let it run for a bit and the oil level didn't change. But it was seeping out of the top shroud. I think it's fixed it's just hard too tell because there is so much oil everywhere. The oil switch is not leaking. and the oil filter isn't leaking.
I'm gonna take it for a rip around the neighborhood and see what's what.
