66 Sedan floor
66 Sedan floor
Took some time and removed the carpet and seats and cleaned up the floor no rust or damage also found a horn button hiding under the seat
Re: 66 Sedan floor
Looks good. Must be from a dry area.
Don't glue down the carpets to every surface!!! The factory only applied glue in foot well areas. You need to pull the carpet back in the area under the dash to access things like the center cover and HI/LO dimmer switch.
