A place to preserve the past, present and future of the Corvair. An ever evolving knowledge base made up of Corvair Enthusiasts from all over the world. (Note: no ads for logged in members).
Corvair lifters are the same as Chevy V8 lifters from the same era. Lifters in a V8 re positioned at an angle, but the horizontal position in a Corvair engine can permit the oil inside the lifter to drain out when the engine is stopped. Because the lifter rotates in the bore and has an oil hole on the side of the lifter, each lifter may randomly come to a stop when the engine is shut down with some having the oil hole facing downward. After sitting for a while, the oil in the hydraulic lifter may drain out due to gravity, which can cause some lifters to cause valve train noise and clatter until oil pressure refills the empty hydraulic lifter. If this occurs the engine valve train noise will usually quiet down after a few minutes of operation, once the lifter has refilled and is fully functioning again to adjust the valve clearance to zero.
