So we recently had some serious rainfall here. Started up the 1968 Monza Corvair and a considerable amount of water came out of the exhaust pipes.
I am a newb without a lot of experience with the make and model. Can anybody give me some advisement on what could have caused this? Of course I am concerned as with a regular engine this is a really bad sign.
Thanks in advance.
68 Monza water from exhaust pipe
Re: 68 Monza water from exhaust pipe
You parked in a low spot that flooded. I had that happen once and it filled some of the cylinders with water also. It didn't hurt anything.
Don't park there.
Don't park there.
I dont think it flooded but the rain was severe, at least 4 hours of straight torrential downpour. I think you're right and it was just a lot of water. It started and seemed to run fine but I shut it down right away. The old water/ cracked block/head gasket reaction. Still not used to air cooled.
As long as the carbs are covered (air cleaners in place) water can not get inside the engine unless there is a flood deep enough to submerge it above the level of the exhaust manifolds or higher. How often is the car operated. Water dripping from the exhaust is pretty normal for cars that sit as condensation forms inside the mufflers and even inside the engine to a lesser degree from air temperature changes. If there was a significant amount of water indie the engine it would show up 2 ways. 1. the oil might have whiteish creamy looking stuff in it and might measure overfull, or 2. the engine would lock up when the starter was engaged as water does not compress well (this sometimes breaks starters or bends connecting rods). Since it started and ran ok, I would check the oil for water symptoms and change it if there are any and then operate it normally thereafter. engines should be operated at least monthly and long enough to get fully hot for a while when operated to boil any condensation and keep it from accumulating.
Thanks TerribleTed. I appreciate the detailed response and will check the oil prior to starting again.
Burning a gallon of gasoline makes 1.52 gallons of water. It all has to come out the tailpipe. By the time the engine is warmed up the water is vaporized enough that you can't see it. Like Ted said when the exhaust system is cold some of that water condenses on the pipe and runs out as liquid.
