When the car is cold, should the choke rod be all the way up or down? Min are all the way up
Choke bellows
Re: Choke bellows
The image below is from the attached 1965 Corvair Assembly Manual - CARBURETOR & FUEL SYSTEM
Also covered in the 1965 Corvair Chassis Shop Manual - SECTION 6 - ENGINE TUNE-UP section (attached). Starting on page 8 of the attached DELCO ROCHESTER - Models H, HV Carburetor Service Manual you will find a detailed description of the automatic choke system.
When the engine is warm, the choke is fully disengaged and wide open. When cold, the bimetallic choke coils are fully relaxed and applying tension to the carburetor choke mechanism. However, the choke butterfly cannot close because the fast idle cam on the side of each carburetor is blocked by the throttle linkage (unloader arm). By pressing the gas pedal once prior to a cold starting attempt, you move the throttle tang out of the way and allow the chokes to set in the closed position, to aid the car with starting. You should check this action by examining the choke settings to ensure that both choke actuation rods are properly adjusted, and that each choke butterfly snaps closed when you manually open the throttle on a cold engine.
![Image](http://www.corvairforum.com/forum/download/file.php?id=34413&mode=view)
- (3.92 MiB) Downloaded 14 times
- (1.79 MiB) Downloaded 16 times
- (8.87 MiB) Downloaded 17 times
- (2.92 MiB) Downloaded 16 times
Re: Choke bellows
Up after you hit the accelerator before you start the engine!!
