how to remove the headlights
64vert
Post by 64vert »
im going to paint the highbeams with yellow stainedglass paint...how do i remove the headlights?
omaha, ne
corvair midwest
CORSA
Re: how to remove the headlights
Remove screws from and remove headlight bezel. Remove screws from around edge on headlamp bulb retaining ring...one edge is held with a spring. Lift back retaining ring from side opposite of the spring and then remove bulb.
Nickshu
Post by Nickshu »
64vert wrote:im going to paint the highbeams with yellow stainedglass paint...how do i remove the headlights?
That's gonna look sweet! Post pics when done please. :tu:
Nick
64vert
Post by 64vert »
couldnt find any stainedglass paint...went to a hobby store (micheals), they didnt have any. theres a hobby lobby close to my house but they dont open on sundays so check there after work tomorrow. also...thanx for the headlight removal instructions! much appreciated!
omaha, ne
corvair midwest
CORSA
JasonC
Post by JasonC »
I had the real deal yellow high beams in mine, but took them out for more cleaner look with the stock T3s . But if you can't find stained glass paint. Duplicolor makes yellow Metalcast that works the same.
1992 BMW 325ic
1997 Jeep Cherokee SE 4x4
64vert
Post by 64vert »
i ordered some online...couldnt find it at any of the craft stores (or any of the other stores for that matter) that the krylon website said carried it. should be here next tuesday or wed. ill post pics when theyre done. havent seen too many earlies with the yellow highbeams...should be cool. (and worth at least 10 hp...right?)
omaha, ne
corvair midwest
CORSA
Augie
Post by Augie »
I used DupliColor metalcast yellow to paint my Fogs on the Saab, Works perfect, you can buy it at most hardware stores. 4.99 a can ish
1962 Monza 900 4dr Powerglide
