Interior panels??
Interior panels??
I have looked at clarks for LM corvair door panels and i want to know if there is any other company that has LM corvair interior options for door panels and liners??? maybe one that has something more custom looking then the factor panels.
Re: Interior panels??
Clark's sells the bare cardboard panels so you can make your own or have your favorite upholstery shop make a set for you.
Dave Keillor
Rochester, MN
Rochester, MN
Perhaps you have already seen the custom 1965 Corvair Monza interior created by Jeff Lilly Restorations in San Antonio, Texas, but I believe that this is one of the best interior designs I've ever seen in a Corvair. It is certainly a model worth considering when you design your Corvair's interior.
http://www.jefflilly.com/gallery/classi ... index.html
DON'T FORGET TO TAKE A FEW MOMENTS TO VOTE IN THE CORVAIR FORUM
CORVAIR OF THE YEAR 2012 COMPETITION. I appreciate your consideration. viewtopic.php?f=189&t=4432
If you're going to do custom work on your car, you should first decide on a theme. I think the Lilly restomod is outstanding, but I took a different approach. The Lilly-designed car is a very nice luxury cruiser. I chose the sport coupe / GT approach. The front seats, for example, were chosen to provide lateral support and firm seating. I threw in a bit of old school hotrod with the diamond upholstery pattern with red stitching. Instrumentation, suspension, steering, engine, and differential are all being upgraded to reflect the GT theme.bbodie52 wrote:Perhaps you have already seen the custom 1965 Corvair Monza interior created by Jeff Lilly Restorations in San Antonio, Texas, but I believe that this is one of the best interior designs I've ever seen in a Corvair. It is certainly a model worth considering when you design your Corvair's interior.
Dave Keillor
Rochester, MN
Rochester, MN
ABSOLUTELY! Both of the above examples are excellent, and both display a consistent theme and careful planning to carry that theme throughout the interior design. Examples like these are very helpful to other Corvair owners to help them to visualize different possibilities and to develop their own ideas and themes. Thanks for the great photos!If you're going to do custom work on your car, you should first decide on a theme.
However....
Just having a theme does not always produce a good outcome!
Ah, yes, execution is vital. Btw, did you know that whatever the theme, that having a pretty engine will increase your horsepower by at least 10%?bbodie52 wrote:Just having a theme does not always produce a good outcome!
Dave Keillor
Rochester, MN
Rochester, MN
what type of paint did you use on your block, heads and exhaust Dave?
The engine castings and cylinder jugs were media blasted by the engine builder (Gary Funkhouser), but I don't know the media type. Exhaust logs and exhaust pipes paint were high-temp paints from Eastwood (I can look up the exact p/n if you'd like). Mufflers are aluminized turbo mufflers from Hedman.mart wrote:what type of paint did you use on your block, heads and exhaust Dave?
Dave Keillor
Rochester, MN
Rochester, MN
unfortunately , bare metal wouldnt last long here in UK before corrosion set in , but what a fantastic finish.
