Turbo Parts ID - Ongoing Effort
Separate from the complete turbo engines, there are a number of turbo parts here. I've never played with them, and don't know enough about them to be confident that I will be representing them properly when the time comes to sell.
Where possible, I am breaking the pile down into gallon-bag-sized groupings. So far, I have 21 of these groupings separated, marked, catalogued and photographed. There is another tote full of turbo items waiting the wings, and at least three other full crates hiding in the stacks.
Any help with IDing these things would be welcome. I will be keeping absolutely none of it.
1) Crown 5041 Exhaust Scroll - One Style
Not drilled for adjuster.
No ratio stamped into base of housing. Were these ever marked anyplace other than around the base?
2) Crown 5041 Exhaust Scroll - Another Style
Has adjuster.
3) Mystery Exhaust Scroll
Has something stamped into the base, but the outer surface is pitted. Not aware of what possible markings I'm looking for.
Has adjuster.
Matthew Rose
Eldersburg, MD
1965 Monza
1966 Corsa Convertible
1963 Rampside
Many Tons of Parts
viewtopic.php?t=20137
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Re: Turbo Parts ID - Ongoing Effort
4) Crown 5041 Exhaust Scroll
5) Mystery Exhaust Scroll
Base is marked.
Housing is cracked. How does this happen? Is this reparable? Is it worth repairing?
6) Mystery Exhaust Scroll
Base is marked.
Oiled by leaky ignition coil.
Base is marked.
Base is marked.
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
7) 180 HP Cold Side
P/N: 3856709
S/N: 43440
Appears to have been cleaned up.
Bearing is snug.
8) 150 HP Cold Side
P/N: 3840830
S/N: 35619
Painted silver.
9) E-Flow Cold Side + Hose & Misc. Hardware
No data plate. There are, however, numbers stamped into the housing where the data plate should be.
P/N: 3856709
S/N: 43440
Bearing is snug.
8) 150 HP Cold Side
P/N: 3840830
S/N: 35619
Painted silver.
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
10) 180 HP Cold Side
P/N: 3856709
S/N: 45043
11) Mystery Exhaust Scroll w/Wastegate (Previously Posted)
Base is marked.
Bolt pattern for base matches that of the Corvair turbo exhaust scrolls.
12) Bendix Stromberg WW Carburetor & Manifold
P/N: 3856709
S/N: 45043
Base is marked.
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
13) Aftermarket Turbo Manifold
14) Turbo Impeller and Shaft
15) Turbo Small Parts
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
16) Turbo Hardware
17) Distributor Pressure Retard
Has a 3-digit marking "224". Not sure of the actual application.
18) Misc. Turbo Parts
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
19) Distributor
20) Distributor
21) Fuel Pump
20) Distributor
21) Fuel Pump
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
22) Some Things Are Too Large For a Gallon Bag
Air cleaner housings and heat shields. A bracket and an exhaust pipe.
The air cleaners are clearly 180s.
Heat shields. There appear to be two different types. Large dent and small dent. Is this a 180 vs. 150 thing? Same HP, but different model year thing? Spare tire vs none, or even coupe vs convertible?
The bracket. Positioned under the tin to help support the weight of the turbocharger?
The pipe. Not marked with a part number. Were these the same between the EM and the LM? If not, how to tell them apart?
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
On the heat shields the large dents are late. '64's are a one year only. It has the same small dent like other earlies but on what would be the front side is a large piece of sheet metal that is attached to the bottom lip of the shield. This shield was to protect the transaxle dipstick boot and is not seen when installed.
23) Turbo Exhaust Pipe and Bracket
In clean condition, but the pipe is two pieces. Can be indexed and either welded or clamped in a given position. Not sure whether this was someone's home brew or a company's product. Also not sure whether it was intended for a 150 HP or a 180 HP turbo.
Matthew Rose
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
Eldersburg, MD
1965 Monza
1963 Rampside
Many Tons of Parts
That looks like a homebrew Matthew, and it is likely not going to fit a stock car, one would have to try mounting it on an engine on a stand with the passenger side shrouds in place, and then fab a crossover pipe to fit. That flange looks like a typical VW exhaust flange, the same that is commonly seen on 140 heads with 1-1/2" exhaust tubes, but I can't be positive, measure the ID on it and the the inlet for the turbo and let us know the size. Probably from a buggy project.
Rocco
Rocco
