1964 Monza Spyder dash
Kramer
Post by Kramer »
Why does my dash have the rectangular slot and two holes on the right? It's a Monza Spyder, so no Powerglide option available.
61SuperMonza
Re: 1964 Monza Spyder dash
Post by 61SuperMonza »
All the spyder gauge clusters have a boss molded into the panel. GM must have planned a version with the PG trans. As to why yours is punched out, I'm not sure. The dash may have came from another car(installed in a PG car in the past). Your horn button isn't from a spyder either. I would research your VIN to see what you have.
First corvair in 1985
Have owned 4 corvairs since
65 Corsa coupe 180 turbo
66 Monza coupe 110 PG
66 Monza coupe 140 PG
Anchorage,AK
Kramer
Post by Kramer »
Parts may be interchanged. We bought this in the mid eighties, from a guy who had quite a few Corvairs. This one is missing the 150 hp turbo engine and had a two carb in its place. I'd like to find a complete '64 150 engine to put back in.
Kramer
Post by Kramer »
Kramer
Post by Kramer »
Sorry for the poor pics. The car is in a heated garage, awaiting restoration.
61SuperMonza
Well good news, the 0627 indicates a spyder coupe. So it a legit spyder. Over the years many things can get changed. I'm sure if you want to find a turbo motor for your car someone here may have one or steer you in the right direction.
I have a 64 spyder motor in my 61 Monza. Love the boost. It really scoots when prompted.
Another tell that your car is a spyder is the exhaust cutout on the right rear panel.
NORM
Anchorage,AK
40627W188614
I will decode the body tag for you...
BODY TAG INFO:
0E (10E?) The first digit may not be visible.
Body Build Date: 10 = October (1963), E = Fifth Week
The first digits are numbers 1 through 12, indicating the month of manufacture. The letter is A-E, indicate the week of the month. If the letter is a "E" it indicates the fifth week of the month.
STYLE 0627 WR 2673 BODY
64 = 1964 (Normally present, but missing on this Body Tag)
Model 0627 — 2-Door Monza Spyder Club Coupe — 4 Passenger, 06 = 600 Series Monza Spyder, 27 = 2-Door Club Coupe,
WR = Willow Run, Michigan Production Plant, Production Sequence No: 2673
1964 Monza Spyder 2-Door Coupe — 4 Passenger, Total Production: 6,480.
TRIM 732
732 = BLUE (Monza with Bucket Seats)
This 3 digit codes represents the interior paint and upholstery color and seat type.
INTERIOR PAINT CODE — "B" (Lower Right) = BLUE Interior paint codes: (Interior paint codes do not appear on Los Angeles built cars)
1964: A= Aqua B= Blue C= Saddle D= Red E= Black F= Fawn Q= White/Red
BODY PAINT 916
916 = DARK BLUE "Daytona Blue"
Lucite No. 4395L, Rinshed-Mason No. A1539, Ditzler No. DDL12696
1964 Corvair Monza Spyder Coupe Example (In Daytona Blue)
ACC: 2LP 3C 5V
Willow Run body tag accessory codes
Group 1
None
Group 2
L = RPO M20 — 4-Speed Manual Transmission
P = RPO Z01 — Convenience group (2 speed wipers, w/washer, day/night mirror, glovebox light, backup lights)
Group 3
C = RPO B70 — Padded dashboard
Group 5
V = RPO A37 — Custom Deluxe Seat Belts - no retractors - RPO A37 (before Feb 1, 1964)
:chevy:
I have attached a copy of the 1964 GM Heritage Center Specifications
1964 Chevrolet Corvair GM Heritage Center Specs.pdf
(2.57 MiB) Downloaded 19 times
Kramer
Post by Kramer »
Thanks for all the info. I'm still confused why the dash has the slot and two holes. Isn't the the Spyder-only dash? I thought the Spyders were the only ones to get a tach, 120 mph speedo, boost (inches HG) and cyl head temp. Which, if I'm right, means no auto trans. So why does mine have what appears to be the RNDL indicator slot. And what's with the two holes?
Maybe I'm wrong, and this is a standard dash. Or at least the bezel (or whatever the aluminum cover) came off a different model.
Again, thanks for the input.
Kramer
Post by Kramer »
That is correct. Spyder dashes did not come with that rectangular hole in them. They did have the bosses in the back for an auto trans lever mount and the casting had a distinct indent from the rear so that if someone wanted to (and I have done a couple) he could cut out the rectangle and install the dash in an automatic car. Your dash has apparently been cut out for some reason. Some P/O maybe stuck a switch there? Maybe the dash was modified for an automatic trans for some reason and then found its way to your car? Who knows?
Kramer
Post by Kramer »
That makes the most sense. This car has been messed with, but not that much. It's a great candidate for restoration some day. Soon as I get a garage and a lift, it'll get a proper 150 engine installed. I'm looking for a complete, proper engine, but I'm not in a hurry to buy. Thanks for all the advice.
The picture below shows the back of the Spyder instrument panel. You can see that the casting was designed to allow for a Powerglide transmission shift lever installation, but GM engineers later determined that turbocharged engine performance with the 2-speed automatic transmission was poor, so the Spyder was never actually offered with an automatic transmission.
Some automatic Ultravans used this instrument panel.
Kramer
Post by Kramer »
Awesome pics. One of these days, this car will get the correct motor and be running again. I have a 110, but I don't want to stick just any motor back in it. I'll post about it here, but it's gonna be a while. Too many other projects.
I stumbled on these Corvair Spyder pictures (slightly modified), and I thought they might interest you – perhaps for some future project! :tongue:
1964 Chevrolet Corvair Spyder coupe - hot rod - GMC 4-71 blower
Outrageous! Car Show - La Verne, CA
