dual master brake cylinder
Picked up one off Summit discount shelf, can someone shoot me the center to center measurement for the mounting on our brake booster? this would be a 65 Corsa. thanks
Re: dual master brake cylinder
Corvairs have no brake booster.
ok, I said that wrong, the single brake reservoir not booster, sorry.
Corvair brake parts are still surprisingly cheap and widely available at your LAPS, even if specal order. It feels like a win anytime I can buy a part locally. I just flushed/rebuilt/replaced my whole brake system. Hoses, hardware, wheel cylinder kits & honing, etc. Even rebuilt the brake pressure differential warning switch. My rebuilt master cylinder from Pep Boys was around $20 with limited lifetime warranty. Hopefully you didn't pay more for Summit's discount deal. Shipping costs often eat up any savings on heavy parts.
Now I'm totally confused. The only match here is that '65s have single master cylinders. You might consider editing your post's title.
Are you asking about mounting dimensions for an unboosted (manual), integral reservoir, single master cylinder to confirm fit?
Does your new one look substantially like your old one in a side by side visual comparison?
If you have the correct dual master cylinder it will bolt right in place of the original single master cylinder. All that remains is replumbing the system so that the rear brakes are fed from the front reservoir of the new cylinder and the fronts from the rear reservoir. adjusting the pedal pushrod length is also often needed so there is proper clearance allowing the master cylinder piston to fully return when foot is off the pedal and have a little 1/8" or so clearance to the rod.
OK I’m driving and using speak and text so I apologize for any misspelled or wrong words. I picked up a dual master brake cylinder from the summit racing discount been at the store in Akron Ohio. I was up in Cleveland for some training. I just need to know center to center measurements for the bolt holes on the regular single reservoir master cylinder for the Corvair‘s. I just want to see if the one I bought I can use, Or find another one that’s got the correct dimensions this is for the mounting it to the firewall. I guess you can’t call the firewall anyway you guys know where it goes. Thanks
Looks to be about 3.5" with a quick tape measure and having to eyeball it since the master is installed.
1963 Monza Spyder project
1964 Monza Parts car
Master cylinders vary by bore size and stroke, just not how they are mounted.
The dual master 67-69 Corvair master cylinder was used on a number of GM cars with manual brakes and as others said "it's available and relatively inexpensive". It bolts up in the single master cylinder 65-66 cars and only needs some added brake line hardware.
Just me, but brakes are too important to be experimenting with unknown parts.
I'll choose a well-maintained factory single MC over the endless number of problems people have trying to switch to dual. Even my V8 Corvair has a single MC and I don't lose any sleep over that. If the last time you checked your brake fluid or did a "hard, harder, hardest test" was over 5 years ago then I guess you should install a dual MC right away.
All Zorm wants to know is the spacing between the two studs on the "firewall". I'm at work so can't go measure it and can't find that info online.
I have no problem using a single MC, but Zorm specifically said he had bought a "dual MC" at Summit. So he apparently wants to go that route. If so why not use a part that works. I'm not sure why folks have "problems" with switching to a dual MC. I've done a number of Corvairs and they all worked as well as the old single MC. Most of the brake issues I run into are worn out brake systems and bad repairs.azdave wrote: ↑Tue Nov 17, 2020 5:51 amI'll choose a well-maintained factory single MC over the endless number of problems people have trying to switch to dual. Even my V8 Corvair has a single MC and I don't lose any sleep over that. If the last time you checked your brake fluid or did a "hard, harder, hardest test" was over 5 years ago then I guess you should install a dual MC right away.
However I've been around too long - LOL, and I've had a few single MC failures AND dual MC failures and even with a dual MC the braking action when one circuit fails is GREATLY reduced. I also use the hand (emergency) brake often when I park a car so if I need it in an emergency I can react quickly.
Yes indeed. If there is a leak when running a dual master cylinder braking action is SEVERELY reduced. People think oh well I will have 1/2 my brakes. In practice is is more like a weak 1/3 of braking. I like dual master cylinders, since a weak 1/3 of braking power is way better than zero.
alrght, I just thought folks were doing duel for better braking. If a single works fine, I'm ok with that. She is only doing weekend duty anyway. I'm not going front disk, unless the brake drum stuff is hard to get. There mixed thoughts on that too?
Brake shoes, cylinders & hardware are plentiful and cheap. Amazon and your LAPS can get everything. I haven't bought any drums for a while but prolly still quite gettable.
IMO stock drum brakes are fine for everyday use. Since you have a single master cylinder, test your emergency brakes regularly and lube the cable rub points under the chassis.
I don't have any problems finding drum brake parts for my LM's. I happen to have front discs on the V8 with a single MC but only because they came on it that way. I would still have drums on it otherwise. On old cars, the hard, harder, hardest test should be a set routine you use every day before you turn that key. I always use the e-brake on all my cars too, not just the Corvairs.
I also practice using the emergency brake while driving occasionally. Hold the trigger release in to avoid lockups and get a feel for how they work. Allow lots of extra room!
WRT to drum brake operation, Google 'duo servo' brakes, whch Corvairs use. There's a lot going on in there, and you actually need to carefully lube the rub points on the shoes for proper operation and prevent lockups. Backing plates can actually wear out.
https://www.hemmings.com/stories/articl ... rvo-brakes
Excellent video by ChrixFix below, very similar to brakes on my '67. My only comment is that he simply replaced the wheel cylinder (on his relatively new truck) without considering honing the old cylinder(s). Cylinder rebuild kits with seals, spring & boots are cheap & easily available online and from your LAPS (may take a day or so). I just rebuilt mine without any problems. The only issue was that the cylinders were too small to use my brake cylinder hone tool (BTW: new unused brake cylinder hone for sale). So I made one using a dowel rod and Scotchbrite, spun by an electric drill. All my cylinders cleaned up beautifully. It's possible to hone & rebuild the cylinders on the car, but on a 50-year old car I would recommend removing them for a full inspection & cleaning.
