Rear Window Zipper
plrgpr
Rear Window Zipper
Post by plrgpr »
Got back from a ride yesterday and a top corner of the rear window was hanging in the well, zipper is now completely shot. The top is absolutely like new. I see as the only option to replace the zipper is remove the top. I’m assuming a lot of expense involved with that. I’m thinking of getting a large needle and strong thread and sewing it shut????
Gary Roberson
Re: Rear Window Zipper
You are right. Replacing the zipper or the rear window are almost as expensive and time consuming as putting on a new top. You can check with a local upholstery shop to see if they have any tricks but I would put the top up (not quite all the way to relieve the tension) and then sew it by hand.
65 Corsa 140/4
66 Corsa 140/4
66 Corsa 140/4 w/factory A/C
66 Corsa 455 Toro V8
65 Monza Convertible 110/4
66 Monza Convertible 140/4
plrgpr
Post by plrgpr »
Thanks for the input Dave. That’s what I’m going to do!
Gary Roberson
