Power enrichment needle. Carburetor
Corsa bill
Post by Corsa bill »
Hi can anyone tell me about the power enrichment needles on my carburetors. It seems that they were only in my primary carburetors. Do I need them at all? And if so do I need them in my secondary carbs.
Ty bill
Re: Power enrichment needle. Carburetor
If the carburetors are drilled for them then you have to have them. The secondary carburetors shouldn't be drilled for the fuel.
:think: You may find the attached DELCO ROCHESTER - Models H, HV Carburetor Service Manual to be informative. About half of this manual is dedicated to operational theory of the Rochester H and HV carburetor subsystems. The power enrichment circuits are described on page 6. The manual does a pretty good job of describing design differences in the carburetors over the various model years.
Another good information source...
:link: http://www.corvair.com/user-cgi/catalog ... w_page=245
:chevy: :confused:
(1.79 MiB) Downloaded 9 times
Bob Helt's Rochester book is worth having. I recall the power enrichment valve was only on the primaries starting in 65. It compensated for a part throttle lean condition. The secondaries are relatively simple, BUT they did change in 66, 67, 68.
