988165 trim rings
bobg1951chevy
988165 trim rings
Post by bobg1951chevy »
I have a pristine 1969 500 Coupe, all stock.
Ebay has factory trim
rings , 988165, which were available for 1960 and 1961.
Will those trim rings work well with my 1969 LM factory wheels ?
If not, are there other Chevy trim rings that will work correctly with my 1969 stock 500 rims ?
Thank you,
Bob.
Bob G., Hendersonville, NC.
1951 Chevy Styleline Deluxe 2 door sedan. 6/2000.
1969 Corvair 500 Coupe # 2671. 7/2017.
Re: 988165 trim rings
The 60-61 rims had bumps around the outside that retained trim rings. I do not believe that the 60-61 trim rings will mount to the 69 wheels (not 100% positive but pretty sure).
bobg1951chevy
Thanks TT, not good news.
corvair500
Post by corvair500 »
I have a set , purchased not long ago , for my 1964 "500" . Just found that they will not fit ..... I have two wheels with those four bumps ( not on car )and they do fit those wheels . I could get two more of the early wheels with the bumps but then my hub caps will not fit them .
Some of the Vega's had trim rings , they may work ???? Best I remember the Vega wheels did not have the four bumps .... Also I do not think Vega rings had the Chevy bow ties.....
One more thing that may work is wire wheel covers with all the spokes and spinners removed .
