1966 Corvair Corsa Convertible SS Rally Wheels
RALLY RIM GM CODE: [9 2 11 YA] Production Date: 1969, February 11, Code: YA
"SS" Style, for Camaro/Chevelle with Disc Brakes YA 14x7 SS
YA — 14” x 7”, Backspace: 4-3/8” 1969 Chevelle SS Wheel
ORIGINAL GOODYEAR RWL TIRES:
Front: Goodyear Eagle ST P195/70 R14
Rear: Goodyear Eagle ST P235/60 R14
BF GOODRICH RWL REPLACEMENTS:
Front: BF Goodrich Radial T/A P205/70 R14 ($119.45 each)
Overall Diameter: 25.4" Revs per Mile: 821 Sect. Width: 8.2" Tread Width: 6.4"
Rear: BF Goodrich Radial T/A P235/60 R14 ($132.45 each)
Overall Diameter: 25.1" Revs per Mile: 829 Sect. Width 9.5" Tread Width 8.7"
The ideal tire diameter produces 825 revolutions per mile, but can go to 850 revolutions per mile and the speedometer only be 3% fast, or 2 MPH at 60.
http://autoxer.skiblack.com/tires.htmlSizing Corvair Wheels and Tires wrote:...I surfed over to The B.F. Goodrich site to come up with some examples of tires that would work well on Corvairs. They have data sheets for all of their tires there, I used the specs from the Radial T/A here, other models will be a bit different. You should be aware that the sizes are a range, so it's a good idea to get the data sheet if you can, especially if you have chosen a size near the limit of what will fit. Unfortunately, BFG doesn't offer a 13" Radial T/A that will work well, these are 14, 15 and 16 inch:
FRONT...
P185/70R14 (all)
P195/70R14 (all, good replacement for 1960 - 65 6.50-13)
P205/70R14 (all, good replacement for 1966 - 69 7.00-13)
P205/55R15 (all)
P195/60R15 (all, good replacement for 1960 - 65 6.50-13)
P195/65R15 (all, good replacement for 1966 - 69 7.00-13)
P205/60R15 (all, good replacement for 1966 - 69 7.00-13)
P205/55R16 (a little tall, may rub on an early, fits lates)
REAR
Late models have a little more room in the rear, you could use these sizes on the rear of a late if you want the "big and little" look:
P225/60R14
P235/60R14
P215/60R15
P225/50R16
